Solved Optical drive often won't read DVD data disks
Mustang
Australia
716
Both optical drives are shown as working properly in Device Manager, but 70% of the time will not read data DVD disks. That includes data disks burnt using Nero and ISO Joliet format; and either mutli-session or finalized after burning. And disks formatted like a flash drive in UDF format using W8 burning software. And is the same for R or RW +/- disks.
Rebooting sometimes fixes the program, other times not.
I have an Intel mob and CPU but Intel do not support drivers for W8 so all drivers are generic W8. Running driver update from device manager says all drivers are up to date.
I also intermittently, but regularly, get the printer and webcam USB2 drives not detecting these devices. And occasionally the USB3 external hard drives. USB drivers are also up to date.
Any suggestions?
    Windows 7 Ult Reatil & Win 8 Pro OEM
    Built as DIY
    6 core 12 thread & 4 core
    Inel Extreme & Intel standard
    12GB & 8GB
    3 top end SLI linked & onboard
    In built in graphics card & onboard
    24 & 23 inch Samsung LED backlit
    High def
    Corsair Force 128GB SATA3 SSDs in each machine. Plus several external USB3 and eSATA spinner HDs
topgundcp
San Jose - California
2,847
  1. Your DVD/CD might be dirty. Wash in warm water with soap.
  2. The read head in the DVD might be dirty. Get a dvd/cd cleaner
  3. Last resort. Replace the DVD.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Mustang
Australia
716
@ topgundcp; Thanks for the input. Have done all of the above. Took a near new but different brand DVD burner from backup PC which runs perfect on Win7 and put it in flagship and same result. Weirdly enough, sometimes the burner on SATA 2 socket does not work, but the one on socket 1 does ... and vice versa. I can't help feeling it's just the mobo not being supported with proper drivers by Intel.
Both burners in flagship are only 3 or 4 months old and don't get a lot of use. Mainly for filing once a fortnight on the Nero burnt discs, and maybe every second or third day on the UDF RW discs
    Built as DIY
    12GB & 8GB
    High def
alphanumeric
slightly off center
Gold Member
Have you tried installing Windows 7 drivers? Create a restore point or make an image before you try it and see what happens. I'd give the chip-set drivers a go.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
my2cents
Veni, Vidi, Vici
2,191
Hi Mustang,
I certainly can't account for why you are having all of these intermittent issues all over the place but as far as the DVD drivers go, they are pretty much generic, and haven't been updated in ages as far as I know. Here's mine for reference:
You can also try this Intel utility to check for the latest drivers if you haven't done so already:
Intel® Driver Update Utility
Good luck.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Mustang
Australia
716
Yes I tried that when I first installed Win 8. And it really was a no go zone. In fact by a process of elimination, I found that the Win7 drivers for USB3 actually corrupted my West Digital USB3 external hard drive and I could not retrieve any data from it. Fortunately I had it all backed up on a 2nd external USB3 HD.
I also tried installing Rapid Storage drivers which Intel say enhance and stabilize the use of SATA drives ... and all my devices are on SATA, eSATA or USB. With Win7, Nero on the same machine would not burn discs until I installed Rapid Storage drivers.
Aside from the drop outs on USB for webcam, printer and external HD on USB3; and on optical drives plugged into SATA ... it runs seamless and very fast.
I'm hoping that Win 8.1 may solve the sporadic glitches.
    Built as DIY
    12GB & 8GB
    High def
Mustang
Australia
716
Hi Mustang,
Good luck.
Thanks for the input. I tried the driver updater from Intel and the only driver it offered was for the wireless LAN. All the others had the same message that it was unsupported.
These are the drivers in mine:
    Built as DIY
    12GB & 8GB
    High def
alphanumeric
slightly off center
Gold Member
#8
No problems here on my old M4N68 ASUS motherboard in Windows 8.1. It's an NVidia chip-set though. The onboard VIA audio was the only thing that didn't work with the stock drivers. I found a driver for that though. I had an old Acer Aspire 5920 that had an Intel chip-set. I never could get windows 8 to run correctly on that old laptop. Like you I couldn't find drivers. It is really old hardware so that wasn't really a surprise. I just put Windows 7 back on it. I did have issues running 8.0 on the M4N68 and eventually went back to Windows 7. Lockups, apps that quit working and some other stuff I can't remember at the moment. I'm actually quit relieved to not have any of those issues with 8.1. Knock on wood, not yet anyway. I did a clean install of 8.1.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
my2cents
Veni, Vidi, Vici
2,191
#9
Yep, we have the same generic drivers and, as you are aware, the unsupported device response simply indicates that is not an Intel based hardware item. Hmm... what is the specific model number of the affected mobo? I saw your specs but I'm not sure what Intel extreme and Intel standard means? BTW, any BIOS updates available for your mobo?
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Mustang
Australia
716
#10
The mobo is a DX58SO2 and is less than 2 years old. And I've got the latest BIOS installed. Intel has all the drivers for it for Win7, which I ran on this motherboard before W8; and there were no problems with Win7.
When I contacted Intel as to why there were no drivers for W8, they said it was unsupported, but they would test that board model, which came out after the original DX58SO was recalled. Intel tech department said they had loaded Win8 on the exact same board and it ran fine with the generic W8 drivers.
@ alphanumeric:
As an experiment I've just tried putting in the Win7 chipset as a one off. Last time I loaded the chipset it was with all the other Win7 drivers. When I installed it just now, the whole screen went black and nothing was working. I rebooted and tried to run it again and it said it had successfully installed. I'll test it for a few days and see if it makes any difference.
    Built as DIY
    12GB & 8GB
    High def
my2cents
Veni, Vidi, Vici
2,191
#11
Good feedback and good alternative testing strategy too! Good luck and let us know.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Mustang
Australia
716
#12
There are no BIOS updates listed at all for Win8. And I thought I had put the latest Win7 one in. However, on checking, I found a new version was released just over 4 weeks ago. So I've installed that along with the Win7 chipset.
I haven't given it a long enough trial, but on three test starts from power off at mains, everything worked. Too early to celebrate, but here's hoping. :p
    Built as DIY
    12GB & 8GB
    High def
my2cents
Veni, Vidi, Vici
2,191
#13
Fingers crossed for you!
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Mustang
Australia
716
#14
So far so good, but I wanted to know if it was the Win7 chipset or the updated BIOS which made the difference. So I reloaded a pristine Acronis image of the OS which meant it now had the latest BIOS, but not the chipset. The same problems kept occurring, so I installed the Win7 Chipset and so far no problems.
So it seems the chipset solved the problem. Even so, the BIOS update served a good purpose because it did seem to run appreciably faster once it was installed. I'll continue to test it for a few more days yet before showing the thread as solved.
UPDATE:
Everything working OK so consider solved by:
  • Updating BIOS
  • Installing Chipset for Win7
Thanks to all for your input. :thumb: :D
    Built as DIY
    12GB & 8GB
    High def
XweAponX
I have an ASUS DRW-24B1ST Sata DVD Burner in my Media Machine, when I installed it under Windows 7, it would read well enough but it would burn coasters on a regular basis. I was getting ready to toss it out, but then I installed Windows 8, and it has been burning successful DVDs and CDs ever since.
Did your Optical Drive come with the OS you have installed now, or did you add it in later? Usually most DVD drives will be detected and installed properly during a fresh Windows install. Sometimes, when you change out an Optical drive, the system may still have the drivers or whatever for the old one still in the system. Now, I usually remove the device and it's drivers (From the Management Console/Device Manager) if I am changing out my Optical Drives. and when I put the new Drive in, Windows pulls out the drivers for the new device, either from cached install files or from the Net.
One thing I have noticed, with drives like Lite-On, is that when there is a Firmware Revision available, they stop working well. You can usually find the latest firmware for a wide variety of drives here:
The Firmware Page • Index page
And there is a request area to request firmware for your model.
There actually is a Firmware Revision for my Asus drive, and I downloaded it, but it does not detect my Sata drive - It's looking for an IDE/PATA drive. I assume the drive I have was made originally as an IDE drive - Or, it came from an OEM system and the firmware may be on the Driver's page for that system, whatever it is or was.
If you have an OEM system, the best thing to do is go to your Drivers page on the OEM website and look for any Optical Drive Firmware Revisions they have available- You will have to know exactly which drive you have. I use Aida64 to tell me what my model number is, there are other programs like Speccy that may give you this info. Otherwise, you have to open the box or and physically inspect the drive and write down any numbers that are on the drive.
After reading through the other responses on this topic, I have to add, Windows XP, Vista, 7 or 8 - it doesn't matter. The Firmware revision is for the Device, not the OS. You can install the firmware revision from any OS and it will detect properly on any other OS. They are little EXE packages that upgrade the firmware of the device, so the only limitation would be if the OS will actually run the EXE file, which Windows 8 usually will do.
So if you find a Firmware Revision for your drive, and you are concerned about the file itself being compatible with windows 8, you can use Hiren's Boot CD and Mini-Xp which is on that CD to run the executable from there. If it does not need to pull up any System drivers or files, it should work.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
Mustang
Australia
716
#16
@XweAponX Thanks for that very informative post. Nice to know exactly what's going on and Firmware page noted.
Cheers M :)
    Built as DIY
    12GB & 8GB
    High def
