old monitor out of range
tinmar49
I was temporarily short of a monitor yesterday so I got my spare 15" out of the loft to tide me by. It is a flat panel 1024X768 with 15 pin d-sub connection. I have multiple boot computers and the monitor worked ok on XP. When I started up in Win 8 it showed the BIOS ok but would not work with Win 8. An " out of range " sign on the screen was all I could get. Switching on and off several times only managed to corrupt Win 8 so badly that I had to boot from a recovery disk and then the Win 8 disk to recover. I tried the monitor on another pc and had the same results except that I didn't mess about with switching on and off and mess up Windows. Both pc's had been connected to full hd monitors but 1024X768 should have been possible, does anyone have the answer?
    win7 64
    athlon2x2 240e
    asus m4a87td evo
    2x4gb ddr3 1600
    ati 5670
tonymarcus
Could you boot into safe mode which will give a low resolution desktop which would enable you to lower the screen resolution to match the monitors resolution?
    Windows 8.1 Pro 64 Bit
    Home Built System
    Intel Core 2 Quad Q9450 2.66Ghz, Overclocked to 3.3Ghz
    Gigabyte GA-EX38-DS5
    8GB XMS2 4GB DDR2 PC2-8500
    Gigabyte 660GTX 2GB
    Samsung SMS27B970D
    1xSAMSUNG SSD 840 Pro Series Basic 2.5" - 512 GB - Boot drive
    2xSamsung Spinpoint F1 750GB
    Corsair 520HX
    Antec P182
    Zalman 9700NT
    12Mb/s
    I did a fresh format and install of Windows 8 64 Bit Pro. Sorry but I couldn't live without a start button so I have installed the Start8 start menu which is great. I try sometimes not to use it but find metro frustrating to find programs as I have many. I will use Metro for apps only and desktop of serious computing.
vrosa
Tech Addict
Boot in safe mode or VGA mode and set your resolution to 1024x768 / 60 Hz. If you can't, then try another monitor to reset resolution.
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
tinmar49
I couldn't get any display at all so safe mode was not an option. Still it is now academic as my LG IPS 224V from Argos £109.99 is up and running. This is absolutely great value for money. I did try lowering the resolution before connecting the old monitor but Win 8 would not go low enough. Windows 7, however would go down to 800X600.
    win7 64
    athlon2x2 240e
    asus m4a87td evo
    2x4gb ddr3 1600
    ati 5670
