Odd partition
boohbah
Closed by request
Having deleted the partition that i had created for win 8 build 7955 i still have two windows seven 's showing in the boot manager there is no partition showing in my computer but it hasn't moved from the boot ,
is there any way to remove this ,also the 30 GB partition still shows in partition wizard but now says unallocated.
    windows 7 /windows 8 Dev
boohbah
Closed by request
thanks ted thats sorted it. i was hoping win 8 would work after removing the rogue win 7 but no joy i have no idea why it wont get past the welcome screen when i open the drive it is installed in it shows all the system files ,windows ,users etc .still a puzzle
Bare Foot Kid
R.I.P. August 13th 2014
Team Member
Hello mate, I'm glad that sorted it for you.
You ought to create Extended partition / Logical drive(s) to dual boot from, Windows will install to a Logical as easy as it will a Primary, the big advantage is it won't be able to interfere with the "System" boot files and when ready to remove that install all that needs done is to delete the Logical and all will be back to normal.
Kodi
Geriatric Member
Try EASY BCD it allows you to edit the boot menu and add a new Operating System (windows 8) also adjust the time out.
    Windows 10 Pro 64bit
    Home Custom Build
    Intel i7-4770K
    Asus Z87 Sabertooth
    16 Gig DDR3-2400
    Gigabyte GT740
    Onboard
    Benq 27" - Benq 22" - Dell 23"
    1680x1050
    Samsung 840 pro 128g SSD
    1xWestern Digital Caviar Green 1TB
    2xWestern Digital Caviar Green 2TB
    Seasonic 760 watt platinum
    HAF-X
    Noctua NH-C12P CPU Cooler
    Logitech illuminated keyboard
    Logitech Performance MX
    Cable
    Avast Internet Security
boohbah
Closed by request
thanks kodi ,i will check it out tomorrow, i spent too long today trying to get this install past the welcome screen ,so its feet up time and chill.
vrosa
Tech Addict
I dont live without EasyBCD :)
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
Dave76
Team Member
Can you post a snip of your Disk Management, make it big enough to give as much details as possible.
    76~2.0
    Intel Core i5-3570K 4.6GHz
    GIGABYTE GA-Z77X UD3H f18
    Onboard VIA VT2021
    22" LCD Dell SP2208WFP
    1680x1050
    Corsair HX650W
    Cooler Master Storm Scout
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
    Desktop: eSATA ports,
boohbah
Closed by request
i have scrapped the idea of installing the latest leak and shall reinstall 7955 .i had the partition fine but the install hangs on the welcome screen i have tried umpteen times with a couple of different iso's but no good. i know the partition was ok as 7955 installed and ran fine.
thanks anyhow dave76
Dave76
Team Member
Did you check the hashes on the downloads?
Must be the installation files if 7955 works.
    76~2.0
    Onboard VIA VT2021
    1680x1050
    Corsair HX650W
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
Britton30
R.I.P. 7/09/2014
I have dumped build 7989. It got to where it wouldn't do much other than boot. MSE, Win Defender wouldn't update, many programs wouldn't even start. I'll wait till the next leak.
    Win 7 Ult X64 SP1
    H.A.L. 2000
    i5-2550K @ 4.4GHz, today
    ASUS P8Z68-V PRO/GEN3
    16GB GSkill Sniper 2133 MHz
    ASUS GeForce 650Ti Boost
    Realtech onboard
    Samsung P2570HD
    Samsung 840 PRO OS, Seagate Constellation 500GB, Users
    Corsair HX650W
    Inwin Dragon Rider
    120mm X4 case fans 3 intake, 1 exhaust , 120mm X2 CPU cooler fan
    some old Dell I found
    steelseries Sensei
    50Mbs/11Mbs
    IE11, Pale Moon, Opera
    NIS 2013
    LG BluRay BD/RE, DVD/RW, front panel w/USB, eSATA, Audio, multi-card reader, Mr Fusion generator
boohbah
Closed by request
i have abandoned my win 8 partition and am awaiting the next leak also. i didnt really use it much anyhow, although it was nice to be a part of the leaks
Dave76
Team Member
Looks like we're all doing what we do best here....waiting :sleep:
    76~2.0
    Onboard VIA VT2021
    1680x1050
    Corsair HX650W
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
Darryl Licht
Not @ ANON
Personally, I will wait for an official beta from MS... I have not had great success with any leaks. IMHO... leaks may be a corporate attempt to mislead the competition (Apple, Android, Google, Linux, etc).
    Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
    Homebrew PC - "Alpha_Dawg"
    Intel Core 2 Quad - Q9550 - 2.83GHz stock - OC'd to 3.6GHz
    Gigabyte EP45-UD3P
    4GB DDR2 800MHz (PC6400) OCZ Reaper
    Nvidia GeForce GTX 460
    Asus Xonar DX
    Samsung SyncMaster 2333HD
    WD Caviar Black 750GB/7200RPM/32MB cache
    WD Caviar Green 2.5TB/5400RPM/64MB cache
    WD Caviar Green 2.0TB/5400RPM/64MB cache
    PC Power & Cooling Silencer 750
    Gigabyte 3D Aurora
    Case is Air - 5ea. 120mm fans (mix of Arctic and Xigmatec)
    50 mbps down/5 mbps up
    AVerMedia - AVerTVHD G2 Dual Tuner Card
Dave76
Team Member
True, maybe the next one will be more revealing.
    76~2.0
    Onboard VIA VT2021
    1680x1050
    Corsair HX650W
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
vrosa
Tech Addict
If the rumors are true this week will probably be a movimented one in the forum.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Dave76
Team Member
And, you were right :D
    76~2.0
    Onboard VIA VT2021
    1680x1050
    Corsair HX650W
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
