nvlddmkm.sys NVIDIA Corporation DPC_WATCHDOG_VIOLATION Please help!!
Stelix
Hello. Please someone help me !!My pc have been crashing many times per day but only when i play games. It always go to that blue screen and appears the dpc watchdog _violation. i tried many things to fix and even format my pc but it didnt work
here some informations i got on whocrashed software :
On Tue 13/02/2018 14:28:11 your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0xc9058)
Bugcheck code: 0x133 (0x0, 0x501, 0x500, 0x0)
Error: DPC_WATCHDOG_VIOLATION
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 390.77
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 390.77
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue).
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 390.77 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation DPC_WATCHDOG_VIOLATION
On Tue 13/02/2018 06:20:21 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021318-42250-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x154EA0)
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Tue 13/02/2018 03:37:12 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021318-233796-01.dmp
On Mon 12/02/2018 13:03:17 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021218-38750-01.dmp
On Sun 11/02/2018 23:05:05 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021118-221828-01.dmp
Conclusion
6 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Please run in an admin command prompt following command
slmgr /dlv
a pop-up will show within a few moments, please make a screenshot of it and post it.
Your Windows activation appears to be a counterfeit, per the forum rules I will not provide support until Windows is activated using a genuine key.
