nVidia GTX 680 problem
jago86
I bought a MSI nvidia GTX 680 Twin Frozr III five months ago.
About a month ago, I was gaming and my computer would lock up and crash. I shutdown the computer, then turned it on, it worked for a little while when I was gaming then the same problem again.
Eventually after restarting/powering off a few times, I got chequered blue squares at post, in the BIOS and right before windows loaded. I couldn't use the computer at all. I left my computer alone for the night and the next day it worked fine, no problems at all even when I played games or movies.
Today I ran into the problem again, after resuming from sleep mode. I restarted and got chequered blue squares.
Now when I turn on the computer I get no signal at all.
Right now I'm using onboard video, computer is working fine. What could cause this problem?
Could it be a power issue?
It's not a temperature issue as my room is air conditioned. Maximum temperature of CPU is 42c and GPU 54c
Computer configuration:
OS - Win 8 Pro x64
Mobo - MSI 880GMS - E35 (7641 v2.0)
RAM - Kingston 16GB DDR3
CPU - AMD Phenom II 965 - 3.4Ghz
GPU - MSI TwinFrozr III nVidia GTX 680 2GB
PSU - Thermaltake TR2 600 Watt
    Windows 8.1 Pro x64
    My Build
    AMD FX 8350 4 Ghz (Stock speed) 95W
    ASUS Sabertooth 990FX R2.0
    Kingston 16GB DDR3
    RealTek HD Audio - Logitech THX Z906 5.1 Surround Sound - 500W
    Samsung 32" LCD Television - LN32D405E3D
    1360 x 768
    Samsung EVO 840 (OS)
    Seagate 500GB (Miscellaneous) 7200rpm SATA 6
    Hitachi 500GB (Games) @ 7200rpm SATA 6
    Hitachi 1TB (Downloads) 7200rpm SATA 3
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Klip Xtreme Multimedia- KMM 101E
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    i love wantons, sushi, fruit cocktail, pistachio gelato and lemon sorbet
    F1 Savant
CountMike
Although that PSU seems quite enough it surely looks like a power issue. If you can, borrow a known good PSU of same or better specs and try. It is not uncommon for them to loose power after awhile and/or can't handle all the components or power fluctuations any more. Also, in some cases, those "chequered blue squares" can signal problems with video card memory.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
jago86
Thanks Mike. I will do that and let you know.
    Windows 8.1 Pro x64
    My Build
    Kingston 16GB DDR3
    1360 x 768
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    F1 Savant
When if ever has the GPU been pulled and cleaned out? What game is this happening with and is it just the one game?
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
jago86
I took it out to clean it once, and it looked as if it was brand new. MSI has this feature where the fans spin in the opposite way when the computer is turned on/off to clean the dust off.
Metro Last Light and GRID 2 also locked up and crashed, but that was before I got problems, and it was because of drivers.
Got chequred blue squares and lock ups when I played Crysis 1.
    Windows 8.1 Pro x64
    My Build
    Kingston 16GB DDR3
    1360 x 768
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    F1 Savant
