Num Lock always activated on lock screen
Khorino
Hi! So, I've upgraded to Windows 8 RTM this weekend and I'm having this problem: Every time I boot the PC (shutdown or restart), the Num Lock key is off. Since my password uses numbers, and I'm pretty used to type it with Num Lock, I'd like to keep it always on. It was fine on Windows 7. Now, I've searched for it, and there is the "InitialKeyboardIndicators" key on regedit. I have changed values for all of them to "2", and it didn't work. My BIOS say to keep it always on. Is there anything else that I'm missing?
Khorino
Netplwiz would be used to automatically log in, right? What I want is to have the key turned on by default, and not having to tap it every time. Also, the keyboard is plugged to the motherboard. As I said, it worked well on Windows 7, so it's a setting on Windows 8.
XweAponX
Check your BIOS as well, most MBs have a "Numlock ON" setting ion the BIOS.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
