Notification settings problem!
Freddie
Hello! I have a problem with notification setting, applications to configure are missing.. How to solve this problem? some solution?
Sorry for my english, attached screenshot for a better understanding of my problem..
Thanks to all! :)
    Windows 8 PRO
my2cents
Veni, Vidi, Vici
Hi Freddie,
I have personally never encountered that before; however, I'm not an app person so I don't often look in that area. Anyway, since no one has responded yet, I'm guessing this may not be an easy fix. However, based on a lack of knowledgeable responses, here's what I would try:
Create a new user account and see if that works:
http://www.eightforums.com/tutorials/5536-user-account-add-new-user-windows-8-a.html
Run sfc /scannow from an elevated command prompt. If errors reported, see tutorial below to continue:
http://www.eightforums.com/tutorials/26512-dism-fixing-component-store-corruption-windows-8-a.html
Refresh you Win 8 installation (read carefully before proceeding):
http://www.eightforums.com/tutorials/2293-refresh-windows-8-a.html
Good luck.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Superfly
Developer
Thanks to all! :)
You may wanna look here - seems to be a reg fix...
    PC-DOS v1.0
    IBM
    Intel 8088, 4.77MHz
    16K, 640K max
    What's that?
    Not quite
    80 X 24 text
