Solved Not Working - Immersive (Metro) Control Panel
Hopachi
Polyhedric Stellation
Hello there.
After some weeks of usage, I've noticed the Control Panel App ("PC Settings") dissapeared from the Start Screen.
If I search for it it's found but it doesn't work after clicking on it.
There is a shortcut in ProgramData on c-drive but it's not working (the same as found on Start Screen I assume).
My guess is that CCleaner removed some entries/shortcuts that were noted as unneeded.
After a sfc /scannow I get reported that errors were found but couldn't be repaired...
Next time I run CCleaner or any other cleaners I'll reconsider it.
Anyone has the same issue or a fix?
Thanks in advance.
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
Hello Hopachi,
You could do a system restore using a restore point (if available) dated before this happened.
If that's not an available option, then could refresh Windows 8 to fix it.
Hope this helps. :)
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Hopachi
Thanks for the fast reply Shawn.
I somehow knew this day was coming... I got tons of files on my Desktop, still working on some projects...
Yes there are a couple of important updates I'll have to reinstall + all newer non-MS drivers.
For the moment I'm not gonna do the refresh yet. It's seems like a minor Issue (one icon) but maybe I'm wrong.
If ohter icons get missing as well (who knows) then I'll definitely do a refresh!
What I also want to add is that after applying the Browser's Choice App (Europe stuff) the Metro IE browser disappeared from all places. I thought this is related to the other issue but some people say that disabling and re-enabling IE from features will restore it's APP back.
As I said in the related thread, I'll re-think my CCleaner usage in the future.
Again, thanks for the post.
Merry Christmas and happy New Year!
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
Hopachi
Are you able to open PC settings using the method below?
http://www.eightforums.com/tutorials/4077-pc-settings-screen-open-windows-8-a.html
For Metro IE10, do you have Internet Explorer set as the default program?
http://www.eightforums.com/tutorials/15045-internet-explorer-10-metro-restore-windows-8-a.html
I hope you have a Merry Christmas and happy New Year as well Hopachi. :)
Thank you!
Yes it works from there. :)
By the way, I also refreshed the pc and some "overcleaned" items are restored. :thumb:
I'll be more careful.
All goes well!
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Great news. :)
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
