Not using all installed memory(RAM)
s00
I have 8GB of RAM installed on the locate system
but, the system can not uses this value.why?
    dell 1510
    i5
    dell
    1G
    15 led
CountMike
Belgrade , Serbia
Run msconfig.exe / boot / advanced options see if maximum memory is checked and if it is, uncheck it or set to amount of physical memory you have.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
s00
I did but the problem not solve
    dell 1510
    i5
    dell
    1G
    15 led
s00
No one can help me???????????????????????????
    dell 1510
    i5
    dell
    1G
    15 led
CountMike
Belgrade , Serbia
Is that a 64 bit win8 ? If it is a 32 bit then it can not use more.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
s00
yes i installed os 8 x64
    dell 1510
    i5
    dell
    1G
    15 led
N30
Closed as requested
Run the System Rating and see if it corrects it.
Also launch Task Manager and see what it says.
    Windows 8 Pro Pack
