Not connecting to Network
Whatever's clever. Good luck!
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Nah, the lease is from your router. The setting is in the DHCP settings at http://192.168.1.1
You'd likely do well to reset your router to factory settings, reboot Windows then check that address to change the lease time.
To reset router, many times there is a small tiny button to push on it with a pen or similar.
I don't have a DHCP section. It doesn't really matter anyway, I wont worry about it.
I'll only do a factory reset if I have to because I've got loads of forwarded ports that need to say that way.
In addition:
Probably a dns configuration error in the router dealing with dns relay and/or not having a preferred dns set in it.
Easiest way is factory reset. Or disable dns relay and actually set a preferred static dns in the router.
I personally use 208.67.222.222. It's fast as can be. My fallback secondary dns is 4.2.2.1 which is also just as fast.
All routers have DHCP settings too.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I did a factory reset, no effect.
The fact that other computers/devices are affected leads me to believe that it's probably my router. The strange thing is that it only is affecting my wired computers.
It has DHCP settings, they're just not all in one place. All I was saying is that I couldn't find the lease setting.
    Win8 CP
It happens. Could be a cooky router, even after the firmware update.
Things to try:
1) If it has a WAN select (or WAN Negotiation speed, Duplex mode or similar), set it to Auto
2) Reboot pc and see how it it. If still trouble, go into the device manager. Right click the Realtek lan driver. Properties | Advanced
For Link Speed/Duplex Mode, make sure that is on auto. If it already is, experiment with the fastest setting shown but only the one saying half duplex.
If no good, try the same fastest setting @ full duplex.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Could refreshing Windows 8 fix it perhaps?
I am starting to get very annoyed with this...
It just constantly says it's "Identifying..."
    Win8 CP
Doubtful.
As a testing procedure, set the driver setting back to auto. Connect the cable from your machine to Optimum Online's (or other ISP) modem. See how things work like that. If it works great, the router is definitely still the issue.
You'd have to reboot the modem though, so it learns your hardware mac address.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I can connect to the internet just fine. The issue is that I can't connect to other devices on the network.
Your screenshot shows problems...and I already said to enable NetBIOS for the adapter.
Other than that, any machine you are trying to share with must have Homegroup enabled and working well too (only works on Windows 7 and 8.)
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I enabled NetBIOS right after you suggested it and nothing changed.
I'm currently using the computer with the issue to make these posts.
    Win8 CP
192.168.1.1
Thanks for the information, it turns out that is your router address and not that of your PC, which is 192.168.1.102, at least it was when the information was posted.
In the ipconfig you posted, it shows NetBIOS as being disabled, now that you've enabled it on the adapter, can you run another ipconfig /all and check the status. In addition, can you open Windows Firewall from control panel and check the status. Post a screenshot if you're uncertain.
    Windows 7 x64 Ultimate/Windows 8.1/Linux
    FX-8350
    GA-990XA-UD3
    16GB DDR3 Corsair Vengeance
    HD7860
    Xonar Essence STX
    Benq
    Various
    Corsair HX 850W
    Corsair Obsidian
    Thermalright
    Logitech
    Logitech
    firefox
On all sharing machines - In Network and Sharing Center:
Click "Change advanced sharing settings" near top left.
For the type of network you're on, set "turn on file and print sharing"
Then all set All networks section like this:1.JPG
At the bottom left of Network screen is also Homegroup settings.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I turned on File and Printer Sharing for all network types, because my machine can't figure out what network type it is.
I turned Fire Wall completely off temporarily and I don't have any 3rd party security applications.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Brandon-PC
Ethernet adapter Wired Ethernet Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-24-1D-1C-72-E9
IPv6 Address. . . . . . . . . . . : 2002:43f2:5052:e472:7400:5ccf:f14b:dab8(P
referred)
Temporary IPv6 Address. . . . . . : 2002:43f2:5052:e472:a5a5:2128:df14:af39(P
referred)
Link-local IPv6 Address . . . . . : fe80::7400:5ccf:f14b:dab8%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.102(Preferred)
Lease Obtained. . . . . . . . . . : Sunday, April 01, 2012 9:09:29 AM
Lease Expires . . . . . . . . . . : Sunday, April 01, 2012 10:37:56 PM
Default Gateway . . . . . . . . . : fe80::e291:f5ff:fe02:5f95%14
192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234890269
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-08-D6-67-00-24-1D-1C-72-E9
DNS Servers . . . . . . . . . . . : fe80::e291:f5ff:fe02:5f95%14
192.168.1.1
    Win8 CP
Something strange is going on here and I'm pretty sure it has nothing to do with Windows 8.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
I'm starting to gather that too.
I have feeling it might be a hardware problem somewhere, the trouble is I don''t know where.
    Win8 CP
Yes that strange IP address "fe80::e291:f5ff:fe02:5f95%14"
right before your default gateway has me confused, not sure what that is but I've seen it before.
Maybe it's possible to adjust the routers advanced settings to get rid of that but I'm sure what setting or adjustment would be required.
It might be something stuck in your IPv4 connection settings somewhere.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
A small recommendation here? Disable all IPv6, disable all Homegroup services, disable IPHelper and use classic sharing method.
Probably not the "correct" way, but I personally despise Homegroup and some routers/adapters have issues with IPv6 right then and there....
Classic will get the job done and well too. :)
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
    Windows 8 enterprise x64
    Pc-Quebec / Area 66
    i7-3960X Extreme Edition
    Rampage IV Extreme
    Gskill 4x4 GB
    4 x HD 7970
    onboard
    2560*1600
    C:\Intel series 520 SSD , 250 GB
    D:\ WD 750 black with Intel 40gb SSD cache Intel RST
    E:\ WD 2TB Black
    Corsair AX 1200
    TT Mozart TX
    Water Cooled
    Logitech G-15
    Windows 8 VM is install on his own SSD.
for me it's the only way
Makes 2 of us man!
Anyhow, I'm sure there is likely to be questions on "how to make classic sharing work well"
If you aren't Windows wizard lol things can get complicated very fast.
We're here to answer anything at all like that, Dr.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
