Not All Hardware Showing
lechumbl
Issaquah, WA
Hi all,
First, this is my first post, so be gentle with me. :dinesh:
In Windows 7 Ultimate 64, all three of my hard drives show up and with data on each one.
Also, my two bluray drives show up and function.
In Windows 8 Consumer, only two drives show up with data. The third shows, but it is not formatted, so can not use it. If I try, it tells me to format it before use.
Also, my first bluray player does not show up, only the second one.
I go back to Win 7, and all show and functions.
Any ideas on this?
Take care........
    Win 8 64
    Homemade
    Core i7-960 Quad 3.3 MHz
    Asus X58
    24 GB Micron DDR3- 1600
    GTX-460
Hi and welcome,
It will make it easier for us to make suggestions if we have more information. Please run Disk Management in both Windows 7 and Windows 8 and make a screenshot of each.
Also, in Windows 8, type msinfo32 in the Start screen then press Enter. File | Save on the opened screen. Then in Windows Explorer, right click the saved file and choose Send To>>>Compressed (Zip) folder. Attach this to a new post when also adding the 2 screenshots above.
We will see what's going on with it all.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi GMan,
Thanx for the Welcome.
I have already run Disk Man on both Win 7 and Win 8.
In Win 7 all three drives and blurays show up.
In Win 8, the third hard drive show as "Raw", and only the second blueray shows.
As far as msinfo32, will get back in the morn with that.
Take care, and thanx for the reply!!...........
    Win 8 64
    Homemade
    Asus X58
    GTX-460
Yep, need the screenshots. You're welcome.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi GMan,
Here ya be.
Take care.......
    Win 8 64
    Homemade
    Asus X58
    GTX-460
Recommend Acronis Disk Director to change the E: drive over to a Primary partition, and set it as active, from within Windows 7.
Of course, backup anything important first, but it should all go well for you without issues. Disable any 3rd party antivirus or security suite before doing anything.
A free alternative that can probably do the same thing is GParted live.
Also to do: In Windows 8, install the latest proprietary storage driver for your motherboard, from the manufacturer's website. Use Device Manager if necessary.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi again,
I am confused:
When I was using the Win 8 Dev Version, all showed and worked fine.
Now in Consumer Version, it does not.
That does not make any sense to me.
Also, one of the Blurays still does not show.
Take care.........
    Win 8 64
    Homemade
    Asus X58
    GTX-460
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi again,
I am confused:
Take care.........
Out of interest, I'm assuming these disks/drives are on different controllers, can you provide any information on how they're configured, i.e., which disks/drives are on which controllers.
    Windows 7 x64 Ultimate/Windows 8.1/Linux
    FX-8350
    GA-990XA-UD3
    16GB DDR3 Corsair Vengeance
    HD7860
    Xonar Essence STX
    Benq
    Various
    Corsair HX 850W
    Corsair Obsidian
    Thermalright
    Logitech
    Logitech
    firefox
Hi Calico,
Thank you for the response.
The C: drive is on SATA 1 controller, D: drive is on SATA 2 controller, and the E: drive is on SATA 5 controller.
My two bluray players are on SATA 3 and SATA 4 controllers
I hope that is what you are asking.
All three are formatted to NTFS files.
Just for grins and giggles, I converted the non working E: drive from NTFS to FAT32, and lo and behold, it now shows and is working perfectly. Go figure.
The first bluray still does not show, but I made some progress, with the drives anyway.
Take care.........
    Win 8 64
    Homemade
    Asus X58
    GTX-460
Now I'm confused about why you'd do this instead of how I showed.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi GMan,
Because, when I attempted to change to it active, I got message that my OS drive would no longer be active and it would not boot there.
Certainly did not want to not be able to boot.
This may not be the best "fix", but it does work.
Take care...........
    Win 8 64
    Homemade
    Asus X58
    GTX-460
Changing the drive to how I said would definitely not affect the other drives and their current active partitions.
You misunderstood the program's warning or were attempting to do something wrong.
It was probably warning you in case there was an OS on that drive.
Glad you sorted though. Recommend NTFS.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi GMan,
Thanx for the help tho.
Really appreciate it!!
Now I/We need to address the missing bluray player.
Take care..........
    Win 8 64
    Homemade
    Asus X58
    GTX-460
Type msinfo32 in the start menu then press Enter. File | save on the opened screen. Zip the saved file then attach it here.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi again,
Already did on the first page of this post.
Please look back for the required info.
Take care..........
    Win 8 64
    Homemade
    Asus X58
    GTX-460
No dice. Can't do anything with a screenshot.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi GMan,
I would suggest converting your newly formatted FAT32 volume to NTFS and running a chkdsk. To convert the volume use:
1. Open an Administrative Command prompt
2. Type - convert E: /fs:ntfs - Where E is the volume identifier.
For the chkdsk:
1. Open an Administrative command prompt
2. Type - chkdsk /f
If it suggests the volume is locked, choose the option to schedule the chkdsk for the next boot. You can 'unmount' the volume manually, but it's better if the process runs at boot time.
    FX-8350
    GA-990XA-UD3
    HD7860
    Xonar Essence STX
    Benq
    Various
    Corsair HX 850W
    Corsair Obsidian
    Thermalright
    Logitech
    Logitech
    firefox
Hi all,
Kinda hard to open a picture, huh? :dinesh:
Here is the zip file.
Take care..........
  • Windows 8 Msinfo32.zip
    Win 8 64
    Homemade
    Asus X58
    GTX-460
Hi all,
Take care..........
Yes, now you're talking. Sense of humor too...good stuff. lol
Visit motherboard manufacturer's website and install latest Marvell storage driver and latest Intel storage driver:
Name    Standard Dual Channel PCI IDE Controller
Manufacturer    (Standard IDE ATA/ATAPI controllers)
Status    OK
PNP Device ID    PCI\VEN_1B4B&DEV_91A3&SUBSYS_84381043&REV_11\4&37C265C7&0&0008
I/O Port    0x0000BC00-0x0000BC07
I/O Port    0x0000B880-0x0000B883
I/O Port    0x0000B800-0x0000B807
I/O Port    0x0000B480-0x0000B483
I/O Port    0x0000B400-0x0000B40F
Memory Address    0xF7EFF800-0xF7EFFFFF
IRQ Channel    IRQ 28
Driver    c:\windows\system32\drivers\pciide.sys (6.2.8250.0, 13.80 KB (14,136 bytes), 2/17/2012 9:20 PM)
Status    OK
PNP Device ID    PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
I/O Port    0x0000A000-0x0000A007
I/O Port    0x00009C00-0x00009C03
I/O Port    0x00009880-0x00009887
I/O Port    0x00009800-0x00009803
I/O Port    0x00009480-0x0000948F
I/O Port    0x00009400-0x0000940F
IRQ Channel    IRQ 20
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
