Solved No wifi connection found
amf501
Hi,
I digitally downloaded Windows 8, and the setup worked fine. However, when I could finally access Windows 8, I could no longer access the internet via wifi. The internet does connect via an ethernet cable, but there is no recognition at all of wifi.
I have the following computer:
Acer Aspire 3-571G
Intel Core i5-3210M 2.5GHz
8GB DDR3 Memory
500 GB HDD
nVidia GEFORCE GT 630M 1GB
Any help would be gratefully received as I'm really not sure why I no longer have wifi access.
Thanks.
    Windows 8 Intel Core i5-3210M
    Acer Aspire V3-571G
    8GB DDR3
    nvidia geforce gt 630m 1gb
amf501
Thanks very much for the quick replies. Here is what I have done so far (unfortunately to no avail...):
Downloaded the Intel Wireless LAN Driver (2nd one down in the "Wireless LAN" section from the links you've given me).
Installed and run this programme, and then restarted.
Unfortunately no wireless connection is still being recognised. I also don't appear to have the "device manager" as per post 2 above installed on my computer.
I will try and download the "Broadcom" wireless driver now, but I'm not even sure if this is the right thing to do!
    Acer Aspire V3-571G
    8GB DDR3
AC
Yes, go ahead and try to install the Broadcom driver. It varies which model WiFi card you might have. If one didn't work, the other is almost guaranteed to work. :)
    W7
theog
Gold Member
Check with the Hardware Vender app
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
amf501
Just checked and it says that I should download the Broadcom driver. Done that now, installed it without a problem, and restarted my computer. However, still no wireless settings detected on Windows 8? I'm going to install the Bluetooth driver as well, and see if this helps.
Otherwise any other suggestions? I appreciate all the help you've given me so far.
Any chance of reverting back to Windows 7? Or would my drivers not be automatically reinstalled anyway?
    Acer Aspire V3-571G
    8GB DDR3
amf501
Just seen on the Device Manager (I found it...), it says that the Qualcomm Atheros AR5BWB222 Wireless Network Adapter cannot start.
    Acer Aspire V3-571G
    8GB DDR3
AC
We'll keep working for 8 before we think about going back to 7.
Can you go to device manager and post a screenshot with Network Adapters expanded?
    W7
amf501
    Acer Aspire V3-571G
    8GB DDR3
theog
Gold Member
What is in Other Devices?
    Notebooks x 3
    Desktops x 5
    Towers x 4
amf501
The "Drivers Download" link currently isn't working for me, but I'll try again with it later. Thanks for letting me know about it.
    Acer Aspire V3-571G
    8GB DDR3
amf501
In Other Devices is "Bluetooth Peripheral Device". The message states that the device is working properly (although when I tried to download the bluetooth driver update earlier, the installation didn't complete due to an error message).
    Acer Aspire V3-571G
    8GB DDR3
amf501
    Acer Aspire V3-571G
    8GB DDR3
amf501
Sorry, I don't think the quality is good enough for you to see there. I'll try again.
    Acer Aspire V3-571G
    8GB DDR3
amf501
Attachment added for screenshot
    Acer Aspire V3-571G
    8GB DDR3
