No Volume Ctl in Tray
wyeknott
Have a fresh Win8.1 Install; over 100 updates installed already.
Audio Adapter: Intel ICH10 - High Definition Audio Controller [B0]
Can't enable the Volume Control for the Tray!
Is there a fix?
It worked fine before all these updates -- I think!
Thanks...
    windows 8.1
    Dell
    core 2 duo
    dell
    4gb
wyeknott
Solved! Use Task Manager to re-start Windows Explorer. Fixed it right up!
    windows 8.1
    Dell
    core 2 duo
    dell
    4gb
