No Store nether Edge apps found after fix
nanakji
1
Hello community. First of all I want to thanks this forum because it helped me to solve the "Temporary Profile" issue which is super annoying. I didn't lose any file or pre installed app, except Windows Store and Edge. I reall don't know how to fix this. The tutorial from this forum I used was this: http://www.eightforums.com/tutorials/38817-youve-been-signed-temporary-profile-fix.html
I had to add a built in administration profile in order to recover the damaged profile, and as indicated on the tutorial you have to erase a bak file in order to do so. After rebooting I dont see any Store app or Edge app or nether the search bar of windows may find it. If you guys know how to fix this I will really appreciate it!!! Thanks and have an excelent weekend!
UPDATE: I'm trying this tutorial: Restore and reinstall Windows Store in Windows 10 after removing with PowerShell but I don't even have the Windows Apps folder so an error message appears at the Powershell :(
Add-Appxpackage : Error de implementación con HRESULT: 0x80073CF9, Error en la instalación. Póngase en contacto con el proveedor de software. (Excepción de HRESULT: 0x80073CF9)
NOTA: para obtener información adicional, busque [ActivityId] 237ea2ac-c8d7-0001-c143-8523d7c8d101 en el registro de eventos o use la línea de comandos Get-AppxLog -ActivityID 237ea2ac-c8d7-0001-c143-8523d7c8d101
En línea: 1 Carácter: 1
+ Add-Appxpackage -register "C:\Archivos de Programa\WindowsApps\Micros ...
+ CategoryInfo : WriteError: (C:\Archivos de ...ppxManifest.xml:String) [Add-AppxPackage], IOException
+ FullyQualifiedErrorId : DeploymentError,Microsoft.Windows.Appx.PackageManager.Commands.AddAppxPackageCommand
    Windows 10 Pro
    Gygabit
    AMD
    gygabit
    HD 5770
    FF
    Malwarebytes
brummyfan
Birmingham
1,487
Hi,
Could you please post this in tenforums to get more response: Windows 10 Forums
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
