No Sound from X-FI Xtreme Gamer
robinbredin
104
    Win 7
    Dell Inspiron 570
    AMD x2
    Dell
    4GB
    ATI HD 5670
    2 x 500GB
    Corsair 600W
    Dell
    Logitech K300
    Logitech G400 Gaming
Im afraid that I have my soundblaster X-FI Extremegamer running fine. Or as fine as it can be running given that Windows 8 is still buggy as hell.
    Windows 8 Dev Preview
    AMD Quad Core Pehnom 2.5
    6GB 1066 Dual Channel
    9800GTX+
[DEL]Im afraid that I have my soundblaster X-FI Extremegamer running fine. Or as fine as it can be running given that Windows 8 is still buggy as hell.[/DEL]
Scratch that, I installed the driver for my extreme gamer and was continually crashing. Infact, even after a total reinstall without installing the drivers, it was crashing. I have now removed the soundcard entirely and am using my onboard sound. So far so good, I will let you know how it goes.
    9800GTX+
2
This is a widespread issue currently for various X-fi cards. People can be a little confused at first because the issue isn't apparent right away after installing the drivers and apps - most people (including me) report that the problems happen after restarting the system and finding that settings have reverted to default (in the Console Launcher) and that there's no sound. If you click on "default", the sound should come back - but this is not a fix, as it's not an option to do this upon every boot/reboot. Your problem might not manifest itself as mine does, but all in all, X-fi and Windows 8 do not work well together at this point.
Windows 8 Pro x64 Retail No Sound after Restart Creative X-Fi Titanium HD Driver
    Windows 7 x64
    AMD Phenom II X4 965BE @ 3.7Ghz
    Gigabyte GA-MA770-UD3 (Rev 2.1)
    8GB G.Skill DDR2-1000 4x2GB @ 800Mhz
    Gigabyte GTX670 GV-N670OC-2GD
BunnyJ
Windows 8 Bunny Guy!
USA/Tenn/Oak Ridge
244
Yea.. I have the same issue. And the same issue was occurring with Vista, it seems to me at least that Creative has issues with their drivers.
    Win 8.1 Pro 64 Bit
    Custom Built: Atomic City Computer
    AMD A4-4000 3.0/3.2Ghz
    MSI FM2-A55M-E33
    8BG of Corsair DDR3 RAM
    On Board
    On Boardi
    Viewsonic 27" VA2703
    1920 X 1080
    Seagate 500GB, Crucial 120Gb SSD
    Thermaltake
    N/A
    Corsair Raptor K40
    Amazon Generic Optical
    56Mbps
    Firefox, Chrome and Opera
    Micro Soft Defender
    Getting this on May 1st:
    AMD A8-6600K
BunnyJ
USA/Tenn/Oak Ridge
244
I found one way around this issue. I re-installed the Win 7 drivers for the sound card. Then I restated the PC. When it was up and going I went into the Creative control panel and selected the Entertainment mode.. the sound was back. I have not tried this with the beta drivers.. but it might work. HTH
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
azasadny
Moved to ten*****s.com
My X-FI card stopped working yesterday after installing a driver update through Win8 Update. I rolled back the driver and the card works fine now. How can I see the updates that Windows Updates is applying? Thnaks!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
BunnyJ
USA/Tenn/Oak Ridge
244
#8
I wish I could help you on that. I hope someone else can answer,.
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
Mitolo
1
#9
works for me I had same prob try adding this to the reg ...
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"CtxfiReg"="CTXFIREG.EXE /FORCE"
    Windows 8 Pro
    Custome
    Intel i7
    ASUS PQ6T Deluxe Palm Ed.
    6G DDR3
    ATi HD6970
BunnyJ
USA/Tenn/Oak Ridge
244
#10
I just tried the Beta driver from Creative and so far so good.
    Win 8.1 Pro 64 Bit
    MSI FM2-A55M-E33
    On Board
    On Boardi
    1920 X 1080
    Thermaltake
    N/A
    Corsair Raptor K40
    56Mbps
    Micro Soft Defender
    AMD A8-6600K
Foxandxss
2
#11
This seems to be a problem with all X-fi cards.
I installed W8 yesterday with the X-Fi fatality professional beta drivers, which I guess are the same for both card. (somewhere around june 2012).
The workaround of BunnyJ works good as hell, and I appreciate it a lot (I was going to open the pc, plug off the card and use the integrated one, but I would miss my ps3 sound ;()
The reg key, I guess it will reset all the sound config, right? That's not good. I changed the line-in to microphone, unmuted the optical and activated Crystalizer.
I think that is faster to simply swap modes two times than configuring the stuff everytime I boot. or am I wrong?
If the reg just activate the sound without having to configure all again, would be good.
Thanks.
    i7 2600
    Asus P8P67
    2x4GB DDR3
    nVidia GTX570
    X-Fi fatal1ty professional
    HP w2448hc / Asus 24"
    3840x1080
    SSD Corsair 60GB / WD 2TB Black
    Temporary crap
    Antec nine hundred two
    Noctua
    Microsoft 10€ kb
    Logitech MX 518
    10MB
akarlz
The problem with all X-Fi Cards under windows 8 is that Console launcher can't save your settings every time you reset your system, there's a solution that I' tried it
on my X-fi XtremeMusic and actually worked, just google "PAX MASTER PCI XFI ALL OS Driver Suite V2.35 Default Tweak Edition" , with some luck you'll be at the forum from PAX Drivers...
    windows 8 pro
    ASUS
    AMD Phenom II X4
    M5A97
    4 GB
    ATI RADEON HD 5700
Foxandxss
2
#13
Tried that driver suite, but no luck (My card is PCIe and not PCI and the PCIe edition of PAX is for Titanium).
Anyway, I have a better fix:
Do you guys have hibernation? I see on many forums that the problem is SSD related and no, Is just hibernation related. And because we the SSD users have hibernation off...
The problem is the way Windows 8 saves the config when shutting the computer.
If you activate hibernation, configure your card and the shut down (not reboot), the config will be saved. Then you can disable hibernation again, reboot, what you want.
I guess that if you want to change more options, you will need to do this again. Anyway, better than nothing.
    i7 2600
    Asus P8P67
    2x4GB DDR3
    nVidia GTX570
    3840x1080
    Temporary crap
    Noctua
    Microsoft 10€ kb
    Logitech MX 518
    10MB
Wayward
1
#15
This is what has worked for me for my Xtreme Gamer and W8 Pro x64:
Install the Creative beta driver
Make whatever changes you want in the Creative Audio Control Panel
Put the computer to sleep
Wake the computer from sleep
Shut down the computer
When you start the computer, settings will have been saved and the sound will work.
    Windows 8 Pro x64
    Intel 2600K
    Asus P8P67 Deluxe
    16 GB G.Skill DDR3 1600
    Radeon 7750
    Creative XtremeGamer
    Dell U2410M
    1920x1200
    Boot: 240 GB Intel 520 SSD; Western Digital Black 2 TB (2); Western Digital Green 2 TB
    Kingwin LZP-550
    Fractal Design Define XL
    Logitech K750
    Logitech Performance MX
Tweakfiend
19
#16
Xfi 5.1 surround does work fully with Creative Windows 8 beta drivers
The other software add on items mostly dont
    Windows 8.1 64 bit
    Self built
    I5 Intel Pentium 2500K
    Asus P8P67 Rev 3.1
    Kingston 16 GB
    AMD H7700 1GB
    Onboard
    AOC 18"
    1680 x1050
    5 Samsung /Hitachi drives ...inc 2 external backups
    2 TB total
    850 watts OCZ
    ICute Silver
    BE Quiet Dark Rock Advanced Overclocker Heatsink
    Wireless MSoft 6000
    Wireless car non Microsoft
    60 Meg
1
#17
Spent all day uninstalling, reinstalling, researching. That did it. Thanks!
    Windows 8 x64
