Solved No signal to monitor after installing new graphics card.
PapaOoige
6
I have a HP Pavillion Model No. p7-1423w I replaced the stock power supply with a 600B 600W Bronze Power Supply.
And installed a EVGA Geforce GTX 660 and have it powered by the new power supply.
When I connect the new graphics card Via DVI-D And I got no signal.
I rebooted into the BIOS to try to disable the on board graphics but I saw no option to do so.
Any help would be appreciated Im nervous about this $320 investment if it doesn't work. Any ideas on what could help?
Simba
Hardcore Gamer
Manchester
47
Did you plug in the 6/8 pin power connectors to the card itself?
    Windows 8.1 64 Bit
    Me
    AMD Bulldozer FX-8 8350 Black Edition @ 4.5GHz
    Asus Crosshair V Formula 990FX
    Corsair Vengeance 16GB DDR3 PC3-12800C9 1600MHz
    Gigabyte ATi R9 280X Windforce OC
    Sound Blaster X-Fi 2 MB
    Samsung Syncmaster SA350 22" LED HDMI
    Seagate Barracuda SATA II 500GB 16MB Cache 7200.12
    Corsair Professional Series Gold AX1200 (1200Watts)
    Antec 1200 Ultimate Gaming Case
    Antec Kúhler H2O 620 CPU Watercooler
    Logitech G510
    Corsair Vengeance M65
    Upto 40Mb/s Fibre Optic Broadband
USA
118
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
alphanumeric
slightly off center
Gold Member
While there may not be an option to disable the onboard, there likely is an option to set which one gets initialized first. Look for a IGP,PCIe,PCI option and set it to PCIe or set so PCIe is first.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
PapaOoige
6
I did figure out how to disable the onboard, however it did not solve the problem, And there is no option for that in the bios at all :[
USA
118
#8
Did you install the driver for the nvidia GPU? Do you have the DVI cables plugged into GPU DVI ports?
Drivers - Download NVIDIA Drivers
No i havent installed the drivers, I thought i needed to do that after the card is already in my PC? and yes the DVI cables are plugged into the GPU
Once you you've turned off the PC, unplugged the power cord, taken side panel off, install GPU into PCIe x16 slot - should be the first PCIe slot closet to CPU, then plug in power cord, turn on PC, after completely booted up, then immediately download the GPU software/driver.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
PapaOoige
6
#9
I get to signal to monitor when I have the GPU in.. All the plugs are in correctly and everything I think it has something to do with Windows 8.. :/
Have you installed the software/driver package yet....?????????????
With out that package your GPU will never work.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
#12
Damned UEFI and secure boot....but I'm glad you got it fixed. Nice find with the link.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
