- Location
- Wynnum Australia
Yes it is, May also feed power to PCI slots and memory in addition to CPU. It feeds to VRM and gets distributed further by it. If your VRM stage is for instance 4+1, 4 feed CPU and 1 would be memory power. If you suspect PSU at all, I would suggest getting a new and better one pronto, it may do damage to your parts if it dies wrong way.Thanks !
~edit~
Is the 8-pin (2x4-pin) PSU cable responsible for the phase that feeds the socket? May a tired PSU be coincidently the cause of the "no-cpu" like behaviour? I don't have another compatible PSU to test, but I think may be a hope!
I think it's the move... Mine is a 3 year old PSU intensely used in gaming rigs.
Maybe just swap it for a cheap basic one, if you have a spare one, as that should be at least maybe enough to power-on your rig.
- Windows-10-Pro-Build-11099.rs1-x64
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom-Build
- CPU
- Intel Core i7 3770k @4800MHz
- Motherboard
- Asus P8Z77-V
- Memory
- G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
- Graphics Card(s)
- 2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
- Sound Card
- OnBoard Realtek® ALC892 8-Channel High Definition Audio
- Monitor(s) Displays
- Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
- Screen Resolution
- 1920x1080
- Hard Drives
- - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
- Samsung 840 EVO SATA3 500GB
- Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
- Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
- PSU
- Corsair AX1200i
- Case
- Thermaltake Level-10 GT LCS
- Cooling
- EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
- Keyboard
- Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
- Mouse
- Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
- Internet Speed
- ADSL2+ ~15MBit/s DL | ~1MBit/s UL
- Browser
- Google Chrome
- Antivirus
- Windows Defender
- Other Info
- - Logitech Extreme 3D Pro Joystick
- Plantronics GameCom Commander Headset
- Logitech X-210 Speakers
- Roccat Taito Mid-Size 5mm
- PC-Master-Race MousePad (yellow)
