No boot and no fan activity (Z87-Plus)
vrosa
Tech Addict
Hello,
I decided to execute a general maintenance on my working computer. I cleaned all parts and contacts with isobutyl alcohol and changed the thermal compound I was using for Artic Silver 5. Now I'm facing a strange scenario. All the motherboard leds turn on when I turn the PSU on but the computer doesn't boot. No post and no fan activity.
May it be a problem with my PSU ?
:shock:
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
theog
Gold Member
5,591
Check all cables & plugs.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
vrosa
Tech Addict
I rechecked everything and realized that when I press the power button the memory leds blink and the "optional CPU fan" spins, but stops immediately.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
vrosa
Tech Addict
It's acting like a "no CPU" motherboard. I really don't get what is happening. The processor was working before I unmount the rig.
:warn:
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Gamer11
Closed as requested
87
do you get any beep code
try reseat your ram and make sure your cpu pins is clean and avoid adding much thermal paste
it can get to the pins and cause short
also check your gpu and reseat it
    Win 10 Enterprise X64
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    4x4 G.skill DDR4 2133mhz
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
theog
Gold Member
5,591
Try reseating CPU.
    Notebooks x 3
    Desktops x 5
    Towers x 4
vrosa
Tech Addict
Still no go !
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Gamer11
Closed as requested
87
#8
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
vrosa
Tech Addict
I'm with a very bad feeling... i found a very small area of the motherboard, near the socket, with traces of thermal compound.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
vrosa
Tech Addict
CPU led in mobo doesn't blink .... I'm getting really worried.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
TONSCHUH
Wynnum Australia
466
#11
Did you bend any pins of the CPU-Socket ?
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
vrosa
Tech Addict
I've checked that but there's no apparent damage to socket pins. The cpu led is now blinking in a 5 second interval
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
vrosa
Tech Addict
sorry... dbl post...
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
vrosa
Tech Addict
The red rectangle in the pic is the area exposed to traces of thermal paste... I'm guessing the worst !
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
vrosa
Tech Addict
I literally washed the motherboard and processor with a mix of ethanol and isopropyl alcohol, then dried parts with a hair dryer. Also checked every screw, cables and power connectors, remounted the machine from scratch, slowly and carefully and...... NOTHING !
Contacting a support partner now. It's becoming a real pain for me.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
CountMike
Belgrade , Serbia
4,664
#16
If it was not metallic paste, it should not make any damage. Could it be that you dropped CPU cooler there ? Take a magnifying glass and check that place for damage. At this point I would take MB out and assemble with just essential parts, adding them one by one and listening for beeps.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
TONSCHUH
Wynnum Australia
466
#17
Arctic Silver 5 is not electrically conductive and should have not damaged something.
Your issue sounds like bent socket-pin's, which happened once to me so far, when I put one build for a mate together. The CPU just slipped of my finger and hit the socket-pin's without any force and still managed to bend some pin's.
You should check them with a magnifying glass and if you see something, then it's possible to get it repaired.
Asus usually charges ~50 bucks for it.
Good luck with your external support !
:shock:
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
vrosa
Tech Addict
Thanks !
~edit~
Is the 8-pin (2x4-pin) PSU cable responsible for the phase that feeds the socket? May a tired PSU be coincidently the cause of the "no-cpu" like behaviour? I don't have another compatible PSU to test, but I think may be a hope!
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
CountMike
Belgrade , Serbia
4,664
#19
Thanks !
~edit~
Yes it is, May also feed power to PCI slots and memory in addition to CPU. It feeds to VRM and gets distributed further by it. If your VRM stage is for instance 4+1, 4 feed CPU and 1 would be memory power. If you suspect PSU at all, I would suggest getting a new and better one pronto, it may do damage to your parts if it dies wrong way.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
vrosa
Tech Addict
Thanks !
~edit~
I think it's the move... Mine is a 3 year old PSU intensely used in gaming rigs.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
