New Hard Drive making knocking noise
17
I have recently gone through a bad run of losing 2 hard drives and having issues with my desktop allowing externals to function properly too. I have just bought another drive and no later tha 3 months it has started making a click noise every minute or so.
What the hell is going on with my machine and why is it just killing off all of my drives!? D:
Any feedback on any ideas would be greatly appreciated.
topgundcp
San Jose - California
2,847
First download: CrystalDiskInfo6_3_2.zip - CrystalDiskInfo
Unzip and run. It will give you some idea about all disks you have in your PC. The symptom you've described sounds like you'll have another bad luck.
What kind/Brand is your PC ? FYI, It is important to have enough air flow and cooling inside the case to keep the temperature of the HD's down. If they are over heated, they'll break down a lot sooner. With my case (ANTEC 1200), All the fans are flowing directly to the HD's to keep them barely warm and they've been in there for 6+ years.
Here's an example:
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
KYHI
2,717
I'm thinking heat or voltage issue
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
TechnoMage
Central Florida
386
That's often called the "Click of Death". It happens mostly on drives with bad sectors on the platters, or where the drive was dropped and knocked out of alignment. I've seen it mostly on Western Digital and Hitachi drives.
Unless your PC is extremely HOT inside, it's doubtful that the computer itself is causing the problem.
Heat Kills...... so when I install a hard drive inside a Desktop PC, I always install a two-fan cooler on the bottom of it.
That does make installation a bit trickier, but it's well worth the effort to have a drive that never gets above room temperature.
A 3.5" internal HD, with dual fan drive cooler attached, using 1/4" standoffs, to promote better air flow.
My own Main HD, with two-fan cooler, mounted in 5.25" drive bay, on spacers, for Max Cooling Air Flow. It never runs more than room temperature, even when hard working like on a scan or defrag.
If your failed drives have been either of those two aforementioned brands, don't buy that brand again.
It's not repairable, so get your data off of there and onto DVD's or Flash Drives as soon as possible.
I might even try a CLONE of that drive to a NEW Drive. Nothing to loose and everything to gain.
Good Luck, and do let us know how things work out for you.
:cool:
    Win-8.1
    Gigabyte
    AMD 8 Core
    Gigabyte
    PNY, 4GB
    NVIDIA, GForce 210
    21" HP
    Seagate SATA III, 500GB
    Antec Earthwatts, 650
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
    AVG Free
    Using Classic Shell on Win-8.1 pro
broe23
Retired from the grind
Central IL
3,468
Something is causing these drives to be knockers. Are these previously used drives, drives you bought on ebay? If the drive has never been thrown across a room or dropped from two stories. Brand new in the box from the manufacturer, you should not get arm slapping.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
17
Hi guys thanks for all the posts and advice, it turned out to be a voltage issue and something was up with my powersupply, thank god it has been replaced and my drives are up and running. Unfortunately I think they have already suffered some permanent damage from this as they seem to make a tiny bit of noise every once in a while.
Hopefully Seagate will warranty them if they get too bad as I sure do not want to fork out on replacements, please let me know any final thoughts if you have any further advice.
jds63
N.Y.
2,214
:cool:
Nice, surprised never seen this idea yet with HDD ! Although have front fan blowing in near mine, 2 out of 3 are SSD's.
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
jds63
N.Y.
2,214
#8
Was me i would RMA it now, why wait.Know it is a hassle.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
17
#9
17
#10
Hi Everyone,
Thanks so much for all your responses so far, sincerely appreciated.
Unfortunately, I have been making some changes to my machine and am still pretty much where I was 3 months ago :(
Since we last spoke I bought an expensive power supply that protects your components from over-voltage, over-power protection, under-voltage and short circuit protection, a better motherboard and a new case to go with. I have also upgraded from Windows 8.1 x64 to Windows 10 x64
As usual, my setup works fine with all my equipment plugged in but until I plug my 2 high capacity drives I have (8TB & 5TB) then the problems start. I now no longer have a PCI card running my 2 big drives as my new board will pick them up fine. When I plug even my other externals in now my externals will work and not drop off after being plugged in for 30 seconds, but they are still being accessed to when I am not doing anything with them and still make a short faint worrying high pitch noise so I only plug them in when I need to access something off of them.
My 5 TB I am sure is on its last leg as from what I can tell it keeps making the 'disk powering up noise' every 40-50 seconds and then when copying a large batch of data to it when copying it goes okay but then the copying comes to a halt then eventually it picks up again and continues to copy.
I am still yet to plug only 1 of the 2 drives into making sure it's not just my 5TB that is on its last leg and hopefully my 8TB is fine not making any high pitch noises. I am however still utterly confused that my machine is still throwing issues at me with my externals (both newish Seagate that behave perfectly normal on other computers)
Any further advice please as I am lost now, I can only think it's some software realted issue.
Kind regards
Alex
Mark Phelps
1,041
#11
Your best bet, at this point, would be to do the following:
1) Go to the Seagate site and download their drive health utility
2) Run that utility against each of the drives
3) If it shows either drive as failing, then start the process of contacting Seagate to have the drives replaced under warranty
The sooner you do this, the better.
Only telling you this because I had a Seagate 3TB go from unreliable to totally failed inside a week. Every day you continue to use these drives, you're risking total failure of the drives.
