Network process freezes when switching from wifi to wired
My motherboard has a built in wifi card, but ofcourse I use wired.
I use wifi for troubleshooting connections sometimes.
When I am done with wifi, I disable wifi - about to enable ethernet. But the wifi does not disable I click disable a few more times but nothing. And I can not enable ethernet.
- Sometimes it can stop on enabling ethernet with that small loading rectangle screen, that will appear for ever...
The only fix when the network process hangs is to hard restart.
I restart the pc from start menu but it stops on the screen "restarting (spinning thing)" - it still spins but spins for ever, so I have to press my PC reset button.
On bootup (i have a 3 places to click in a picture for the password) when I click the 3 places, it is still waiting for more clicks or "start over", if i wait long enough it finally realises I have already done the 3 clicks correctly and lets me in.
    Built my self
    Intel i7-5820k
    Asus Rampage Extreme V ROG
    Cruical 4x 4 GB 2133 mhz DDR4
    GTX 780
    Acer XB270h 27" G-Sync 144 Hz
    3x 256 GB Samsung 850 Pro
    Corsair AX850
    NZXT Phantom
    Noctua NH-U14S + 7 Case fans
    Trust Elight
    Razer Deathadder 3500
    Down: 45 mbits/s Up: 12 mbits/s
    Windows 8.1 built in
bump ?
    Built my self
    Intel i7-5820k
    GTX 780
    Corsair AX850
    NZXT Phantom
    Trust Elight
