Network problem!
Castravete01
Hello! I installed OS 8 and my network doesn't work!The "Local Area Network" doesn't appear!I did a new connection(every time when I reinstall the OS I must do a new connection,a PPOE connection),no result.What I can do?
    OS 7
znod
To make things easier maybe, go to the Desktop, right click on it, choose personalize, and select the Desktop icons you would like to show, including Network and Control Panel. Then, check things out in Control Panel > Network and Sharing. Be sure your network is shown as Private. Run the troubleshooter. See what things look like when you go to the Change advanced sharing settings link in Network and Sharing. If I am a little vague, then please forgive as I am on a Mac far away from my Windows machine. To facilitate things, show your network icon in the taskbar notification area.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Castravete01
Now I have installed OS 7,so please more replies,I don't want to change windows every 30 mins..I will search some help.Thank you for reply,I will try.You can tell me how I can see a private network,or change his mode?Please help me...
    OS 7
znod
The instructions I gave above will work in Win7 or Win8. You are looking for a screen like the following. I downloaded this from the web. As said, I am on a Mac right now. Since you are in Win7 now, you should be on your Desktop. Try to accomplish what I said in my first post.
    EVGA 570 SC
    Gateway
    Dual Boot:
Castravete01
If I download my network board driver(I have a "Broadcom Netlink Gigabit Ethernet" board),The Local Area Network will apear and my network will work?
    OS 7
znod
Have you checked in device manager under either Win7 or Win8 to see if it shows a problem with your driver. Are you interested in connecting only via Ethernet?
    EVGA 570 SC
    Gateway
    Dual Boot:
znod
    EVGA 570 SC
    Gateway
    Dual Boot:
Castravete01
This is what I found!Look,the network board is compatible,what's the problem?So,some time ago,when I bought my desktop pc,I installed windows 7,after I wanted windows XP,but I had the same problem with network,the Local Area Network doesn't appear and my network doesn't work.Now I have windows 7,and I want windows 8,but I have the same problem.What's the problem?Can I resolve this problem?
    OS 7
znod
Are you trying to connect through a router? If yes, you could try connecting directly through your modem to see if anything is different. You could try uninstalling your antivirus software if you have either Norton or McAfee. For Norton, go to the Semantec website and use the provided installer.
    EVGA 570 SC
    Gateway
    Dual Boot:
