Need replacement Network HD
mickyd
UK
As per my last post i am going to buy a new home network storage device - trouble is they have changed since i bought the last one and doesnt seem as simple - i have no idea what i am looking for :oops: - so i am therefor more lost than lord lucan =
Can anyone give me some advice and what the best NAS (i think thats right 😕)
SO any help appreciated
Thanks
Micky
    Own Build
    AMD FX8350
    ASUSTeK Computer INC. M5A78L-M PLUS/USB3 (AM3R2)
    32.0GB Dual-Channel DDR3 @ 803MHz
    4095MB NVIDIA GeForce GTX 1050 Ti (ASUStek Computer Inc)
    Soundblaster Z
    Benq
    C: Sandisc Ultra II 240GB
    D: Toshiba 3=2TB
    E: WDC 1TB
    1 rear 1 top 2 front
    70mbs
    firefox
    MBAM, ccleaner
Barman58
Super Moderator
Super Moderators
Newport, South Wales, UK
A lot of modern Routers will allow you to attach a Hard Disk in a USB case which is a simple solution and If you have the hard disk available it's a low cost solution, cases are around the £20 range for a tool less unit. If you need to buy the hard disk that will add a larger cost.
With the actual Network Attached Storage proper, costs will increase again but they are more usefull devices, allowing you to access externally from your network and stream media on PC, Laptops, and Phones, you can also run apps on the NAD to perform automatic Backups etc
I have one of these TerraMaster F2-210 2-bay NAS Quad Core Raid Enclosure Media Server Personal Cloud Storage (Diskless) : Amazon.co.uk: Computers & Accessories
which houses a pair of 3TB drives I had hanging around
    Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
    Real World Computing
    AMD FX8350 8 Core @4GHz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    ASUS Xoner DG + SPDIF to 5.1 System + HDMI
    Acer G276HL 27", (DVi) + Samsung 39" HDTV (HDMI)
    1920 x 1080 @60Hz + 1920 x 1080 @60Hz
    Internal
    Crucial 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS
    Seagate ST4000DM000
    Aerocool Templarius Imperator 750W 80+ Silver
    AeroCool X-Warrior Devil Red Tower
    Stock CPU, Rear 120mm, Front 2x120mm, Side 2x120mm
    Logitech Wireless K710 & K270
    Logitech Wireless M710 M185 & M570 Trackball
    37Mb/s Down - 9.5Mb/s Up
    Chrome
    BitDefender Total Security 2017
    Also run...
    Desktop - 6Core 8GB - Windows 10 Enterprise x64,
    Laptop - Quad 8GB - Windows 10 Pro x64
    Netbook - Ubuntu
    2 x Nexus 7 Android tablets
    Samsung 10.2" tablet
    Sony Z3 Android Smartphone
    HTC One Android Smartphone
mickyd
UK
I have been looking at them they get good reviews - does it matter what HD`s you put in them?
    Own Build
    AMD FX8350
    Soundblaster Z
    Benq
    D: Toshiba 3=2TB
    E: WDC 1TB
    70mbs
    firefox
    MBAM, ccleaner
Barman58
Super Moderator
Super Moderators
As with anything that you will likely come to rely on, and of course your data - Photos, music., games etc - are your most important assets, so I would suggest you get the best you can afford, there are a range of prices and there are also specifically designed hard disks for heavy use which are best left for business use.
It's often the case that with more than one person using the NAS it will get heavier use than you would see with a drive in a PC used by one person, but personally I have found that for home use any of the known manufacturer's drives will be up to the task
    Asus M5A78L-M USB3
    Internal
    Crucial 256GB SSD,
    Toshiba HDWD130 3TB
    External (USB3)
    NAS
    Seagate ST4000DM000
    Chrome
    Also run...
    Netbook - Ubuntu
mickyd
UK
Yeah its just me that uses it - for PC, laptop and ipad to access (ipad backs up its photos ony) I play my music from it using the laptop - thats really about it
    Own Build
    AMD FX8350
    Soundblaster Z
    Benq
    D: Toshiba 3=2TB
    E: WDC 1TB
    70mbs
    firefox
    MBAM, ccleaner
mickyd
UK
    Own Build
    AMD FX8350
    Soundblaster Z
    Benq
    D: Toshiba 3=2TB
    E: WDC 1TB
    70mbs
    firefox
    MBAM, ccleaner
Barman58
Super Moderator
Super Moderators
It will work fine with a single disk and you can then add a second when you are ready. If you fit 2 drives at the start you can set them up as a single drive using the RAID option built in which can be useful for management. This can be done later of course but can be a little more complex to do when you have data on the drive
    Asus M5A78L-M USB3
    Internal
    Crucial 256GB SSD,
    Toshiba HDWD130 3TB
    External (USB3)
    NAS
    Seagate ST4000DM000
    Chrome
    Also run...
    Netbook - Ubuntu
mickyd
UK
    Own Build
    AMD FX8350
    Soundblaster Z
    Benq
    D: Toshiba 3=2TB
    E: WDC 1TB
    70mbs
    firefox
    MBAM, ccleaner
