Solved Need help with setting up home network
onlytanmoy
103
Dear All,
I have a query--apart from the Homegroup option..is there any other way via which files can be shared between my Win 7 32-bit laptop & Win 8 64-bit desktop?
I am looking for something like-- upon clicking the PC name in the explorer, a window prompting for password will pop up and then upon entering correct password (may be the PC login password), the shared folders will be accessible?
Am sure Homegroup is the easiest solution out there. But I would like to know the other way too.
Thanks,
Troy.
    Windows 8 64 bit
    AMD FX-8350 4.00 GHz
    ASUS M5A97 EVO R2.0
    8 GB DDR3 Corsair Vengeance 1600 MHz
    SAPPHIRE HD 7950 3GB GDDR5 OC with Boost VAPOR-X
    Onboard Realtek HD
Shadowjk
Network Enthusiast
    Windows 8.1 Pro 64-bit ; Windows Server 2012 R2 Standard
    Custom Built
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP (CPU 1)
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD Radeon HD 6800 Series (Sapphire/PCPartner)
    Realtek High Definition Audio
    SMB1930NW + AOC 2243W
    1440x900 + 1920x1080
    977GB Seagate ST31000524AS ATA Device (SATA)
    250GB WD iSCSI attached drive
    750W PSU
    Novatech Night
    Dell Standard PS/2 Keyboard
    R.A.T 7 Gaming Mouse
    Optiarc DVD RW AD-5260S ATA Device
23,371
    3 x 27" Asus VE278Q
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
onlytanmoy
103
@Josh & Shawn>> thanks a lot for the resolution guys.
Forgive my noobness but one query-- whatever computer joins the homegroup, they will be visible in the Windows explorer, right? I mean no machine which has joined my homegroup can stay hidden?
    Windows 8 64 bit
    ASUS M5A97 EVO R2.0
    Onboard Realtek HD
23,371
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
onlytanmoy
103
thanks for clarifying my doubt Shawn..am really proud to be a member of eightforums family..marking this thread as 'solved' :)
    Windows 8 64 bit
    ASUS M5A97 EVO R2.0
    Onboard Realtek HD
23,371
You're most welcome Troy. :)
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
onlytanmoy
103
#8
@Shawn>> Is there some kind of network monitoring software which I can install in my Laptop (where I have the shared folders)..so that when I try to copy data from there via my desktop...a notification will be shown in the Laptop indicating that some User has connected to it and accessing data? Please advise.
    Windows 8 64 bit
    ASUS M5A97 EVO R2.0
    Onboard Realtek HD
23,371
#9
Hello Troy,
I don't know of one, but you might post that as a new thread in Network & Sharing to see if someone may know of something for that.
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
Shadowjk
Network Enthusiast
Unless the share accessed appears in Event Viewer, I am not sure whether you are able to accomplish such task without SNMP which in order to use without proper network equipment will require Windows Server (Essentials, Datacentre or Standard) to receive the echos and create traps or a third party application to be installed on a workstation. Please be advised that the later could have radical performance impacts.
Just my input based on networking monitoring tools I use ;)
PRTG is the best I use for my cisco devices however I have not tried on workstations and unless there is a 'plugin' the only way of finding such information would be to filter traffic so that only packets flowing to the IP address of your machine are monitored. This will include broadcasts (ARP) from local machines as well as internet browsing packets that you make when browsing the internet so it may not be accurate. - PRTG Network Monitor - intuitive network monitoring software
Just my two cents,
Josh :)
    Custom Built
    750W PSU
    Novatech Night
onlytanmoy
103
#11
thank you, Josh....i will check out PRTG.
    Windows 8 64 bit
    ASUS M5A97 EVO R2.0
    Onboard Realtek HD
