Need help with my laptop connected to my HDTV (HDMI Cable)
21
Hey guys, I'm actually new here, so I am not sure if this is in the right forum page, but I need help. I have had a problem with my HDTV and laptop for a few months and finally decided to start a thread for help. The problem is that the HDTV is blurry and fuzzy when connected to my laptop via HDMI. However, I realize this is an overscanning issue, because in the AMD Catalyst Control Center, whenever I set the scaling for overscanning to 0%, the fuzzy text and screen is fixed, but the edges around the screen like the taskbar are cutoff the edge of the screen. I do not think my TV has an option for "Just Scan", but maybe you guys can find something I can't. Here is the manual:
http://www.sansuiproducts.com/images/manuals/SLED2280D.pdf
Also, I am running Windows 8.1 with an AMD Radeon HD 7520G graphics card.
Any help is appreciated, thanks. :)
    Windows 8.1 (64-Bit) and Windows 7 (64-Bit) (Dual Boot)
    AMD A6-4400M, 2 cores, 2.7 to 3.2 GHZ speed
    8 GB DDR3 Memory
    AMD Radeon HD 7520G
    1366x768
popeye
United States
3,090
Not sure I can help but I have the same thing. I have a cheap TV and I think it has more to do with that. I play videos is all and not an issue there, just desktop is expanded past screen.
My TV is only 720p.
I'd love to see if someone has a fix.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
21
Haha yeah it's so annoying. I really hope someone on here knows how to fix this.
    8 GB DDR3 Memory
    AMD Radeon HD 7520G
    1366x768
DMHolt57
Austin, Texas
1,252
What happens when you set your desktop resolution to match the native resolution of the TV? :geek:
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
21
Thanks for replying, do you mean the native res of the TV? I have it set to its native, which is 1920x1080.
    8 GB DDR3 Memory
    AMD Radeon HD 7520G
    1366x768
21
It still has the edges cut off when scaling on AMD CCC is set to 0%, which is the scaling I want it to be at.
    8 GB DDR3 Memory
    AMD Radeon HD 7520G
    1366x768
