Solved Need help with graphics accelerator
msmith1969
Hi.
Recently I purchased a Dell Inspiron 3847 Desktop.
3.10 gigahertz Intel Pentium G3240
Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller
After installing all the programs I used on my old Windows XP PC I learned that an image viewing program, PMView, is not properly working on my new system.
I contacted the man who created PMView who told me I most likely need to adjust/turn-off graphics acceleration.
When looking at the properties for my machine's graphics I learned the graphics accelerator installed on my machine can not be adjusted or turned off. http://i.imgur.com/i7HDsvD.png
I contacted the PMView creator who suggested I try a OEM graphics driver that is compatible with Windows 8.1.
Admittedly I am not technician, though I am fairly good at following directions. I am hoping a person with tech knowledge can help me find a graphics driver that can be adjusted or disabled.
Thanks, Mike :)
    Dell Inc. Inspiron 3847
    4GB
    Intel(R) HD Graphics
    100 Mps
    Avast
Because your graphics are integrated, it would be nearly impossible to find a driver for it. It has no dedicated memory, which could be one of the problems with it, and the actual acceleration is BUILT IN, so it cannot be changed.
    CyberPowerPC
    AMD-FX 6300 3.5GHz (OC'd @ 4.1GHz/4.5GHz)
    760GM-P23 FX
    x2 4GB DDR3 ADATA RAM Sticks (1333MHz/ea)
    MSI AMD ATI Radeon HD 7750 2GB
    Realtek HD Audio Integrated Sound (7.1 Surround Dolby Pro)
    Insignia 22" Flat-Panel LCD TV
    1TB Generic Hard Drive
    Sentey ERP750W 750 Watt PSU
    CyperPowerPC Ultra Gamer Series 1
    DBB Silent Fans
    Razer Death Stalker
    AZZA Generic Gaming Mouse
    10/MB UP 3/MB DOWN (Soon to be 25/MB Down 10/MB UP)
    Headset: Astro A40 Mixamp Pro 2013 Edition
The PMView website claims it is compatible with Windows 8. Be sure you have the latest version as older versions may have issues.
If the computer came with Windows 8 installed we can reasonably assume it has compatible drivers.
Altering acceleration settings (a global setting) seems a poor way to resolve an application problem.
    Windows 7
Thanks, ItsSmooth. What you say makes sense. Looking around I learned Dell placed the least popular card in the machine I purchased. Though the graphics are a vast improvement over my old custom machine. Like night and day.
LMiller, yes I installed the latest version of PMView, I updated the drivers that Dell Diagnostics said my computer required, still no luck. I haven't a clue why my machine and PMView aren't friendly. I've discovered an alternative to PMView, so this is no longer an issue.
Guys, thanks for your input. :)
    4GB
    100 Mps
    Avast
