Solved need help with adware
jeffrys
hi guys,
recently i was visiting a lot of sites for help with my Excel/Visual Basic problem. Now every day my www.yahoo.com starting page is changed to HOME.FIZZW.COM (yousearchdirect) and even with the adware removal program i ran...nothing changes.
Anyone knowing how to get rid of this?
thanks
Jeff
    WINDOWS 8.1 x64
    INTEL CORE I--3770K LGA1155
    ASUS P8Z77-V
    KINGSTON 2400 MHZ KHX24C11K4 16GB
    INTEL HD GRAFICS 4000
    Philip BDL3245€ 32 inch
    2 SAMSUNG 840 PRO RAID 0 ON BOARD 2 x 128 GB
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
vrosa
Tech Addict
Look in control panel / add remove progs and remove anything that you dont know what is. It include IE bars and such soft. Use MSCONFIG to check what is beeing loaded in startup.
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
jeffrys
thanks Vrosa,
well it is not at startup, i do not shut down the computer often. It happens every day around 12.00h.
But i will try to find anything in the programs.
Jeff
nothing found in Programs.......
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
DustSailor
Although I'm not familiar with Win8 browser options, I assume it is the same as Win7 with IE9. look under manage add-ons>search providers and make sure that one isn't in there, and make sure there are no add-ons with that name as well. Then change your home page in "Internet options".
    Windows 8.1 Pro with Media Center x64
    Custom
    Intel Core i7-3820 CPU OC @ 3.80GHz
    Gigabyte G1.Assassin2
    Corsair Dominator 16GB Quad Channel DDR3
    Nvidia by EVGA - GeForce GTX 670 4GB
    On board Creative SB X-Fi
    acer 24" H243H
    1920 X 1080
    Main 500GB Hybrid Drive @ 7,200RPM
    Secondary OCZ SSD Vertex 3 Max IOPS
    Silent Pro 1000w gold 80+
    Azza Hurrican 2000
    Liquid CPU cooler & fans
    Microsoft Comfort Curve 2000
    Tek Republic Wired Laser Mouse
    5ms Ping 5.15Mb/s Download .64Mb/s Upload
    Internet Explorer
    Defender, Malwarebytes
jeffrys
hi DustSailor,
nothing special under Manage Add Ons.....
Deleted the key in the registry, still the same.
I hate it that i am not in control of my computer.
Thanks anyway
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
vrosa
Tech Addict
hi DustSailor,
Thanks anyway
Jeff
What AV are you using ?
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
The Howling Wolves
Both Are Veterans
    Windows 7 Home Premium S 64 bit
    HP
    Intel Core 2 Quad Q6600 2.4GHz
    ASUSTek
    4 Gb Dual channel DDR2
    512MB GeForce 8500GT
    HP w 2408 Vivid Color Widescreen LCD
    Cooling Budweiser now
    MS intell keyboard
    MS intelli Mouse
    US Postal Service
DustSailor
Are you sure you removed the virus? I don't know how well antiviruses are performing in win 8 o.0
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
jeffrys
well right now i do not use any AV, since my F-SECURE is not working under Win8.
But it is not a virus, it is a software redirection i have. Maybe uninstalling IE and reinstall would help?
It is nothing to be afraid of, just bothers me.
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
DustSailor
Here is an IE troubleshooter for IE9 from the Win7 forums. While I don't recommend downloading anything from it (Don't know about compatability), you can try to manually follow the directions to see if you can fix IE10: Troubleshooting Internet Explorer Issues - Windows 7 Forums
I'd be very very careful without an antivirus. I know many don't work well with Win8 yet, but its still dangerous. :eek:
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
vrosa
Tech Addict
AVG Free 2012 works fine.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Kynix
Am I int the right place?
but, Actually Windows 8 comes with built in smartscreen protection. So it isn't so unsafe than with xp, vista or even 7.
    Windows 7 x64 Home Premium / Commodore OS Vision / Windows 8 Release preview
    AMD Athlon x2 Dual Core 7750 BE 2,7Ghz (2/4)
    Asus M2N-e
    4Gb
    GIGABYTE (ATI) Radeon HD 6870 (1Gb)
    Do i have one?
    1x HD1080 1x SXGA
    1x Samsung 500 Gb
    1x Samsung 30 Gb
    1x LaCie 1Tb Hard drive.
    Antec 500W
    Antec three hundred
    3 fans + psu and cpu + gpu
    Logitech G19
    CM Storm Xornet
    110mb/ s
    Look, what i've created... just a few visits at the recyclement center was enough...
jeffrys
Well Dusty,
i am on Win8 now for about 3 months and do not worry about viruses right now.
Free antivirus do not work as should.
Example, i used Avast free AV and when having a virus in Outlook, Avast could not remove it. But i forced Avast to remove it anyway and the whole PST file was removed.....
The difference with F-Secure and others, which are not free, they remove the record....
but thanks
Right now my worry is that i am not in control of my PC, not viruses.
Jeff
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
Jav
I don't have access to Windows 8 right now. But I think it had access to Group Policies.
So thats what you can do:
1. open (run as admin) group policy editor (press start type gpedit.msc ) Alternatively C:\Windows\System32\gpedit.msc
2. Navigate to: User Configuration -> Administrative Templates -> Windows Components -> Internet Explorer
3. On the right side find setting called "Disable changing home page settings"
4. Double click on it and change it Enabled and put in your desired home page
Now nothing can change your homepage. Only way to change it through the same menu again.
But I would still recommend to find the core of the problem, what is changing it in the first place?
    Tetris
DustSailor
Keep in mind Win 8 is still just going through testing, nothing is solid yet. It might not even be perfect when they start rolling it out, that is why they send out Service Packs and updates. If you have problems now, I wouldn't worry about it at the moment. You can send microsoft a little note about the problem and hope they fix it (higher chance of them fixing it if you do). Be patient ;)
    Custom
    acer 24" H243H
    1920 X 1080
    Azza Hurrican 2000
    Internet Explorer
jeffrys
Well Jav,
just changed as you said. Now i have to wait until tomorrow (between 13.00h-14.00h, time when the start page Always changed.
Probably it will be ok, but i let you and everyone know, since......this can happen to anyone.
I search for a long time and still haven't found anything. Strange....
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
Mike Lonewolf
It is nothing to be afraid of, just bothers me.Jeff
Hi Jeff, try this; Go to the Norton website, and download the Nortons 360 v6 beta, let it scan your system.
360 works perfect in Windows 8DP. I'm not only talking about only the AV, just run all the tests. It is quick so you won't be sitting there for days waiting for it to complete.
    Windows 8 pro Retail
Kynix
i would suggest you thef-secure online scanner it does not install anything, it will only load up using java, and check your system.
    Asus M2N-e
    4Gb
    Do i have one?
    1x HD1080 1x SXGA
    1x Samsung 500 Gb
    1x Samsung 30 Gb
    Antec 500W
    Antec three hundred
    Logitech G19
    CM Storm Xornet
    110mb/ s
jeffrys
ok Mike and Kynix,
will try this out.
In the meantime and for the first time since weeks, my Yahoo.com is not changed. Thank you Jav, you solved my problem.
This can help a lot of guys here.
Jeff
Forgot, i am running f-secure on-line scan right now. Strange because my own F-Secure is not (or was not) working on Windows 8. Will try to reinstall it.
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
jeffrys
well guys,
F-Secure on line scan finds.........nothing......
will try Norton now.
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
