Solved Need Help Registring A Manually Installed Programme
midou35000
Coming Over
Hi,
I Have Manually Installed this programme (San Andreas) An there is a special programme that mods san andreas and when it starts up it says: Screenshot_1.png
I have put the folder in this location:C:\Program Files (x86)\Rockstar Games\San Andreas
So any help to register this programme.
Thanks
    Windows 10
    HP
    Intel Core i7
    Nvidia Geforce GTX 680
    idfk
    15' 1080p display
    70Mbps
    Google Chrome Canary
    AVAST Premiere 2015
adamf
Banned
did you buy it?
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
midou35000
Coming Over
did you buy it?
Yes i did buy i have two PC's i just copied the installation files from the PC that i bought it from and putted it in my laptop i didnt want to run the setup from the CD
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
adamf
Banned
Don't you think you should install it then?
I don't use games but you can not generally copy things around like that. Your executebles have to be registered and so on.
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
midou35000
Coming Over
Hi Again,
Okay I Give up am gonna install it with setup.exe
You Have got a rep for making me give up :)
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
adamf
Banned
thanks - honestly you will always fail just copying various .dll etc. You can (individually) register them but it is almost always easier just to run the setup.exe
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
midou35000
Coming Over
You Got That Right
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
midou35000
Coming Over
Lol You Wont Belive i installed and found the registry value :p
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
adamf
Banned
guess that is what it is for (although I'm not a windows programmer).
It would be terrible if you got some program and then its instructions said: copy something here, regsrv32 this, and that and so on
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
