Navigation Pane Order
Bad213Boy
Favorites
- Desktop
- Downloads
- Recent places
Libraries
- Documents
- Music
- Pictures
- Videos
Homegroup
Computer
- Local Disk (C:)
- Local Disk (D:)
Network
Something that has been bugging the hell out of me, since Vista, is that the old XP file explorer was replaced with the new Libraries opening window. That's fine, but why the hell does Computer have to be all the way to the bottom.
Ya if I was a novice user I might be inclined to use those folders more frequently, but as an IT guru, this is nuts. If I download, move, or copy anything to an external hard drive, USB, or DVD, I always have scroll down the Navigation Pane. This is such a little thing that it's almost stupid that you can't slide these categories up and down. This way users can set their most used categories to the top. If you can move columns back and forth, it makes no sense that you cant do it for the nav pane.
I know I can make a shortcut pointing the file location to %SystemRoot%\explorer.exe /E,::{20D04FE0-3AEA-1069-A2D8-08002B30309D} will allow me to create the Computer shortcut which can be use to pin to the taskbar. I've seen 3rd party software bring back the old XP explorer nav pane and I've also seen one that either adds or hides the Navigation Pane items.
It really is silly not to add something like this that is so simple to do for Microsoft. But does anyone know if there's any registry entry I can use, or some 3rd party software that does this for Windows 8?
    Custom
    Intel® Core™2 Quad Processor Q9650
    XFX nForce 790i Ultra SLI
    Corsair Dominator GT 8GB (2 x 4096MB) PC3-17000 2133MHz
    Tri SLI ASUS GTX 470 1280MB
    Mozilla Firefox
    Norton Internet Security 2013
Lee
USA, Idaho
1,062
Hi Bad,
Welcome to the "Eight Forums." . . .:thumbsup:
Try this; close all the folders above "Computer" then open "Computer" then close Explorer (file manger). Now reopen and everything should be the way you want it. Did this several times to see if any would change and it didn't. This worked for me, albeit it doesn't mean it is the answer you are looking for. . .Good Luck.
Hope to see you around the Eight Forums again an IT guru is always a big plus and the Eights.
    Win 8, (VM win7, XP, Vista)
    HP Pavilion p1423w
    Intel Core i5 3330 Ivy Bridge
    Foxconn - 2ADA Ivy Brige
    16 GB 1066MHz DDR3
    ATI Radeon HD 5450
    HD Realteck (Onboard)
    Mitsubishi LED TV/Montior HD, Dell 23 HD, Hanspree 25" HD
    Mit. 1980-1080, Dell 2048-115, Hanspree 1920-10802
    1 SanDisk 240Gig SSD, 2 Samsung 512Gig SSDs
    Tower
    Original (Fans)
    Microsoft Keyboard 2000
    Microsoft Optical Mouse 5000
    1.3 (350 to 1024 if lucky)
    Firefox 19.1
    MSE-Defender
yuricuri
60
I have a similar situation, I completely agree Bad123Boy... I dont get why I can put the Computer uptop, ahead of Favorites (i have a long list), i never use Libraries or Homegroup or network. I understand what you mean though, Lee.. But still it would be nice to rearrange the order on the left panel so you dont have to constantly scroll down.
    Windows 8 x64 Home Edition & Windows 7 x64 Professional
    HP Envy DV6-7250CA & Samsung NP355V4C-S01CA
    Intel Core i7-3630QM @2.4GHz & AMD Quad-Core A10-4600M
    8GB DDR3 @ 1600GHz & 6 GB DDR3 @ 1600GHz
    Intel HD 4000 + NVIDIA GeForce 630M 2GB & AMD Radeon HD 7660G + HD 7670M Dual Graphics 1GB
    1366x768
    SHAW Extreme
    Chromium
    MS Security Essentials, Malwarebytes Anti-Malware Pro 1.7
Computer Drives near top ?
I moved my drives up.
Is what is in the picture what you are looking for ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
yuricuri
60
Thank you for taking your time to do the screen shot, and post on here, that is exactly what I meant but without having go through adding it to favorites. Of course that works your way, and I will use it. But wouldn't it just be a simple piece of logical code for Microsoft to say, hey maybe the user might want favorites at the bottom, and computer at the top, or how about letting the user have the option to decide for themselves by being able to drop and drop the order of the top tiers. you know?
Anyways I appreciate your help, and this did solve my dilemma, so Thank you! :)
    1366x768
    SHAW Extreme
    Chromium
Bad213Boy
Ya I guess that's one way to do it. It's just so weird to me though right? Ehh, I guess that works for me. I guess I just have to make more endless shortcuts to windows 8, lol.
    Custom
    Mozilla Firefox
pparks1
Westland, MI
3,658
Just don't forget, "It's Windows 8, and it was my idea". It's exactly customized how you would want it and if not....well...then it was likely a bad idea anyway and you would be better off just moving on.
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
yuricuri
60
#8
LOL
    1366x768
    SHAW Extreme
    Chromium
