Solved My laptop doesn't charge battery when it is on!!!
arvinwebb
New Delhi, India
63
I am running windows 8 pro wmc on my HP laptop. One month ago I have bought a new battery. From last one week, when I start my laptop it shows that "plugged it, not charging". When I shut down down, it started charging the battery. After a full charge, my laptop performs good and battery worked for almost more than 2 hours.
Please help me. Whats the issue with my laptop. Thanks in advance for your help.
    Windows 8.1 64
    Lenovo
    4th Generation Intel Core i7-4510U (2.00GHz 1600 MHz 4MB)
    Lenovo Y40-70 (U3E1)
    8.0GB PC3-12800 DDR3L SDRAM 1600 MHz (1 x 8.00 GB)
    AMD Radeon R9 M275 2GB
    Realtek
    14" Full HD
    14.0" Full HD LED AntiGlare Backlight Display (1920x1080)
    Hybrid 1TB 5400 RPM+8GB SSHD
    Lenovo
    Cooler Master NotePal X-Slim Ultra-Slim Laptop Cooling Pad with 160mm Fan (R9-NBC-XSLI-GP)
    Lenovo
    Microsoft Wireless 3500 series
    4 MB/sec
    Google Chorome + Microsoft Internet Explorer
    Norton Premier Edition 2014
Ztruker
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
XweAponX
Sometimes in the BIOS they have a utility that trains your battery. But you can do it Manually
To do that, charge the battery to full capacity, then unplug your adapter and use your laptop until it has 5% or less of battery left. Then charge it full again, and drain it again. Repeat this process at least 5 times.
Only 2 hours for a new battery is not good, you should be getting at least 3 if not 4 hours of use.
If it will not charge while powered up, there may be something wrong with your Power Block on the laptop. There are chips on the motherboard that become unseated due to heat, and fans stop working. You got to take the laptop to a Laptop only shop and they can re-seat the chips, check your fan and clean the system. That may be what it needs. The places usually charge a couple hundred bucks to do it, it's hours of work.
Also check the connector, while it is powered up, jiggle the power connector a little, see if it starts charging.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
arvinwebb
New Delhi, India
63
Maybe you need to Calibrate the laptop to the new battery: Calibrate Laptop Battery
Thanks to both of you my friends. I have taken your advice in my mind and I will do so as per as your suggestion. And then give you feedback about charging performance.
XweAponX: My laptop fan is working fine and there is no problem of heating too much. the temperature of my laptop is quite OK after working 4-5 hours on laptop.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
Let me ask you this, when plugged in, does the system stay on? If so, it may be charging and not showing the status correctly in the tray.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
arvinwebb
New Delhi, India
63
Yes Sir....when i plugged in charger the system stay on. But it showing in the tray that "Plugged in, not charging". Sometimes in between it started charging but it goes only for few seconds.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
Well, I've seen HPs and Toshiba's that did this, try unplugging it and plugging it back in a few times, eventually it should start charging.
Also, go through your advanced power settings, set your maximum Processor speed to 80% when on Battery, 100 for plugged in.
Set the minimum CPU to 25% plugged in, Max to 100.
There are a bunch of settings for battery as well, go through those make sure they are all set to default. I dont have a laptop so I cant remember what's all there.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
arvinwebb
New Delhi, India
63
#8
I did it. But there is no option to set CPU usage.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
It's there, under "Processor Power Management" in Advanced Power Settings. Open you power settings, and get into Advanced settings from there.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
#10
Sir, I checked that option. But there no option to set CPU usage.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
It says "Processor" - Set it to 80% for battery.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
#12
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
mikeytg
Joisey
315
#13
Are you using the power adapter/cord that came with the laptop? Perhaps something has gone wrong with it so it has enough power to run the computer or charge the battery, but not both at the same time.
    Windows 8.1 consumer 64 bit
    Acer Aspire M5 481PT-6644
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
I am using the same adapter that comes with laptop. The problem has raised from last 10 days. Before that, everything was fine.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
You know, maybe the power adapter is going bad. How old is this system? You can find a replacement on Amazon or eBay, sometimes the exact model, for cheap.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
#16
My laptop is three years old and as adapter.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
Then the adapter may be going bad. If there is a Laptop Store anywhere near you- A shop which sells only laptops, you can bring it there and they may let you test a new adapter. I use a place called "Laptops Plus" - They are national, so there may be one hear you. There is another one called "Laptops USA" also national.
Setting your Processor Power to 80% while running on Battery, this is not a solution but it is a way to make your battery last longer.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
arvinwebb
New Delhi, India
63
#18
Thanks to all my dear friends for their suggestions. Now, suddenly my laptop started working fine. Charger is now working perfectly.
Thanks once again.
    Windows 8.1 64
    Lenovo
    Realtek
    14" Full HD
    Lenovo
    Lenovo
    4 MB/sec
XweAponX
OK! I hope it stays working! Maybe a combination of the things... But I think it may have been recharging all along. My Gateway laptop before it broke, would be connected to WiFi but the tray icon showed not connected, even though it was.
Sometimes windows just goes goofy. OK GreaT! Mark this as solved if you havent already, if it comes back we can try more things.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
