MS Movie Maker will not work with my Windows 8 - HELP!!!
MartielB
Hi everyone,
I need some help. I film online classes, so I'm really up against a time crunch as I have a production team waiting on me, let me cut to the chase....
I need my Movie Make to work. It worked just fine when I had Windows 7, but now (As a Windows 8 user) when I try to save anything the system says it is trying to repair the problem and then kicks me out.
I only really use Movie maker for the trim tool and a few other features, as it is so easy to use. However, I have an enormous file that will not compress any further. I need to trim it in order to send it but Movie Maker will not allow me to.
How do I fix this? Is there another option? Why is Movie Maker not compatible with 8?
Janie
I am having problems too - I have Windows 8 , I have downloaded the free Movie maker from the Windows site . It looks the same as the version I had before but it doesnt work. If I get any replies with info I will let you know
What version are you using? The latest version is 2012.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
Hopachi
Polyhedric Stellation
I used the program from way back in the past.
It came as a feature in Windows XP and Vista.
After I used Win7 I read that I have to rely to a newer online downloaded version.... but I copied the one from Vista and it worked fine.
It still works on Win8, no issues. So you might give it a try if you still have a Vista iso or install somewhere.
Another thing, if you know VLC, they began making a movie maker based on VLC. It's still in development like more than alpha but you can check that out if interested:
Index of /~jb/vlmc
This one works for some simple project but I recommend you stick with the Windows Movie Maker for more stability.
Personally, the Movie Maker form Vista is the way to go, but every one has its own preference.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
MartielB
I think I have a later version. My computer came with Windows 7, bought it late last year. Then I upgraded to Windows 8 the beginning of this month. Ever since Movie maker has been on el fritzo. Where do I go to get the latest version?
I just downloaded WLE 2012 and selected to download movie maker and picture viewer. went to my pictures, picked 4 pictures and added some music and saved it. It saved it just fine, closed out software, went to destination folder and found it and played video...it played just fine.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
@ Janie and MartielB; did you guy upgrade over 7 or do a clean install of windows 8?
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
Janie
I have a new laptop with windows 8 installed on it . I got the free download of Movie maker from their website . I am so frustrated that I cant get it to work properly and there doesnt seem anywhere to get help. I am surprised there are not more people with the same complaint .
Janie
OK I have been experimenting - Uninstalled everything to do with the movie maker and started again.
I find that it couldnt read the MPEG files from my video camera ( they were fine on Vista ) So I tried converting them
I checked the new movie maker help pages and it says -- I can use all these files
  • Video files: .asf, .avi, .m1v, .mp2, .mp2v, .mpe, .mpeg, .mpg, .mpv2, .wm, and .wmv
I have experimented and now find that MPEG can be viewed on the timeline but only the audio plays on the preview screen and
WMV can be viewed on the preview screen but not the timeline ????????
In any case I dont want to have to convert everything it takes ages
I havent got any further so dont know if anything else works
MartielB
I am unable to do anything as it states every time I try to save "An error has occured, MS will contact you if an solution is available". EH? I'm so lost right now.
BTW, did the update, now Movie Maker is in French. Awesome....guess it is good I can read french. :)
Dubbledoo
Personally, the Movie Maker from Vista is the way to go, but every one has its own preference.
Movie Maker from Vista is superb. The Windows version from 7 was abysmal, so I took it from my old Vista machine and loaded it onto my 7 PC. Now I've downgraded to 8.1, is it the same process as described here;
Windows Movie Maker 6.0 - Install on Windows 7 - Windows 7 Help Forums
Thanks.
    HP Pavillion
KTR
We have a new Windows 8.1 PC which operates fine but Movie Maker stops during editing the Project every time! Projects include .jpg-photoes and short .avi videos.
We reinstalled the whole Windows Live package: no help! We have also Media Plaer installed ok. What to do??
(We have used Movie Maker with W7 PC a lot and were very satisfied with it.)
    Windows 8.1 64 bit
    Asus K30BF
    8 GB
    F-Secure
