Solved Move partition from left of C: to the right of C:
m0nk3n
pls does anyone know if there is a way to move a partition \ unallocated space from the left of the C: drive to the right of it so that i dont waste the unallocated space?
can i do that in windows? cause i think i tried that one about 2 hours ago. i released the power in the laptop i got. removed the recovery slugging the pc to hieell because it logs everything so they can see whatsup when we send it in for "repair" when they just add another "recovery" (log) layer and its slower when we get it back. removed all the acer programs have deemed effective everytime i had a laptop. threw mcaffe out of the planet. started using defender :D
i tried resize \ move the partition but didnt quite get how it worked since there were no other partitions to move it past in the window that function brings.
think it's better just to keep a usb with windows 8.1 iso on it since it has no cd\dvd rom. it got stuck on updating reverting changes for about a day then i restarted and it wouldnt boot said i needed to boot device. got on my desktop and downloaded win 8.1 using media creation tool and voila recovery worked fine outside the recovery partition which instigated that the partition was locked and i needed to unlock it to use the recovery partition.
That unallocated partition just might be either the factory restore/recovery partition or the boot partition for your Windows. Windows explorer.exe does not read or report the contents of those partitions. How large does disk management report that partition to be?
600 MB. it had no name or anything. but the other one is called "system reserved" and is uefi 300mb
i just installed 2 gb ish of updates and the boot is working fine. so dont worry about that 600mb partition.
Although I've done something similar, the process of doing so, the process of ensuring data is not lost, is quite a geeky one. I'm at school, hit or miss on this computer.
