How to Create a "Mouse and Touchpad" PC Settings Shortcut in Windows 8.1
This tutorial will show you how to create or download a Mouse and Touchpad settings shortcut that opens directly to the Mouse and Touchpad settings in PC settings in Windows 8.1 and Windows RT 8.1.
EXAMPLE: "Mouse and touchpad" in PC settings in Windows 8.1
To Download a "Mouse and Touchpad" PC settings Shortcut
Mouse_and_touchpad_Shortcut.zip
3. Open the .zip file and extract (drag and drop) the shortcut to your desktop.
4. Unblock the extracted shortcut.
6. When finished, you can delete the downloaded .zip file if you like.
To Manually Create a "Mouse and Touchpad" PC settings Shortcut
If you do not have a US English Windows 8.1 installed, then you will need to change the en-US folder name in the command below for the folder name with your language instead for this to work.
%windir%\explorer.exe %localappdata%\Packages\windows.immersivecontrolpanel_cw5n1h2txyewy\LocalState\Indexed\Settings\[COLOR=#ff0000][B]en-US[/B][/COLOR]\AAA_SystemSettings_Input_Touch_EnableTouchPad.settingcontent-ms
3. Type Mouse and Touchpad for the name, and click/tap on the Finish button. (see screenshot below)
4. Right click or swipe down on the new Mouse and Touchpad shortcut, and click/tap on Properties.
%SystemRoot%\system32\DDORes.dll
- How to Create "Mouse Properties" Shortcuts in Vista, Windows 7, and Windows 8
- How to Set the Left or Right Mouse Button as Primary in Windows 8 and 8.1
- How to Turn On or Off a Precision Touchpad in Windows 8.1
- How to Turn On or Off Leave Touchpad On when Mouse is Connected in Windows 8.1
- How to Enable or Disable Touchpad Edge Swipes in Windows 8 and 8.1
- Turn On or Off Reverse Scrolling Direction of Precision Touchpad in Windows 8.1
- How to Change Delay or Turn Off Taps for a Precision Touchpad in Windows 8.1
- How to Turn On or Off Double-tap and Drag for Precision Touchpad in Windows 8.1
- How to Turn On or Off Right Clicks for Precision Touchpad in Windows 8.1
