Mounting iso file problem
mashebro
hi
i have iso file with file size 16GB, when i mount i got problem can not see all file in the iso (only 30 file from total 143 file)
i try to open with winrar i can see all file buat only 30 with the extension and complete file name, other file there is no extension and file name not complete
what should i do to extract all the file in this iso?
thx
    windows 8.1
    Tablet
MilesAhead
Eclectician
Is there an MD5 Hash for the ISO file? Perhaps it is corrupted.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
popeye
Does sound corrupt. What does 7-Zip show?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
alphanumeric
slightly off center
Gold Member
Some file extensions are hidden if "Hide extensions of known file types" is checked under the View tab in Folder Options. Just so you know.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
jimbo45
Hi there
If it's a blu ray iso I think "Houston --We have a problem". Otherwise anything should work. Blu ray's IMO aren't long for this world either --expensive, or so riddled with DRM etc that the format is essentially on its last legs -- direct Internet download as MKV / mp4 is far less restrictive and gives proper full 1080p even on 60 - 70 inch screen too.
If it's simply photos or data consider splitting the file up into smaller file sizes.
BTW forget WinRAR - 7ZIP is far superior in EVERY WAY. 7-Zip
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
