Monitor vs HDTV for gaming
tylr6024
13
Hi there.
I have a 24 inch monitor and I am looking into getting another screen for a dual set up. My brother let me borrow his 24 inch HDTV/monitor and the picture looks great. I was thinking about getting the same one but before I do I wanted to make sure I am not overlooking things.
Are there any concerns about using a HDTV rather than a monitor? Are their things to be worried about a year down the road?
Thanks
    Win 8
CountMike
Belgrade , Serbia
4,664
Technically no, just open some things with small text to see how clear the picture is, most TVs are not made with sufficient resolution to handle small stuff. Keep in mind that most games want to run on the primary display so you'll probably have to make TV primary and if it's not good enough for small text than you may have problem or would have to move applications to your now secondary display.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
28
In my experience using a TV as a monitor wasn't as good as an actual monitor. Even with disabling all motion settings, setting the input to PC, and tweaking other things, there was always a noticeable input lag. I was using a 120Hz led tv as well. The response time wasn't as good as my pc monitor is. The picture looked great and all, I just couldn't get over the input lag from using a tv. Trying switching the input on your TV to PC and that will also make a difference for you. Just me, personally, I prefer using a monitor for my pc. Good luck!
    Win 8.1 Update 1, 64 Bit
    EVGA GTX 660
