Solved Missing Wifi Driver
droniexx
N Wales UK
Hi all
I had a crash with my windows So i formatted my drive and clean installed win 8.1. when I tried to install my wifi driver it wouldd not install so i went to Dell to download the driver they gave me the wrong driver te driver I need is a proset intel 8260-7265-3165-7260-Wifi-Driver_3FJFP-WIN_20.10.1.1190_A24.EXE.nnuz dell offer a 8265 bluetooth which will not work I went to intel and they told me to access the driver I need to be registered so Itried and I could not register so I need help from someone please I definatley need the nnuz file again the driver required is ( intel 8260-7265-3165-7260-Wifi-Driver_3FJFP-WIN_20.10.1.1190_A24.EXE.nnuz) thank you
    win 8.1
    worstation 7710
    i7 6th gen
    64 GB
    deicated Intel HD 530
    Realtek
    3840x2160
    the SSD total 3.24TB
    worstation /Laptop
    Twin Fans
    Wireless
    firefox 64 bit
    AVAST PREMIUM
Teeotsa
Estonia
Hi all
This one? Intel 8260 7265 3165 7260 WiFi Driver | Driver Details | Dell Estonia
    Windows 8.1 Professional x64
    i7 3770
    ASRock B75 Pro3-M
    HyperX Fury DDR3 2x4GB 1866MHz + 2x2GB Samsung Sticks (12 GB Total)
    AMD R9 270X
    Some :) Enough for me
    10 Mb/s Down | 2Mb/s Up
    Google Chrome 108, Internet Explorer 11, Firefox 80, Edge 107
    No third-party Antivirus software is installed on my system.
    No Windows Update/Windows Defender & Antivirus Software on my system.
droniexx
N Wales UK
    win 8.1
    worstation 7710
    i7 6th gen
    64 GB
    Realtek
    3840x2160
    worstation /Laptop
    Twin Fans
    Wireless
    firefox 64 bit
    AVAST PREMIUM
Teeotsa
Estonia
Hi thank you Teeotsa that is the right driver it worked fine I have made a copy seperate from my drivers disk(usb) I did how ever put the driver discription into dell but never got that response Thank you I can close this post after your help.
You're welcome! 😁
    i7 3770
    ASRock B75 Pro3-M
    AMD R9 270X
TechnoMage
Active Member
Central Florida
I've installed Windows 8.1 on several Dell laptops, and never had any problem with 8.1 installing the correct driver so that the built in WiFi worked perfectly.
Windows 8.1 is just great about installing working drivers for various hardware.
Cheers Mates!
TM :cool:
    Win-8.1/Pro/64
    Acer X-1200
    AMD 2 Core
    Acer
    Crucial, 4GB
    NVIDEA GeForce 9200
    On Board
    24" Acer
    Sandisk, SSD 500GB
    Acer
    SFF Slimline
    emachines 101 key
    Logitech Wireless
    5 Meg
Teeotsa
Estonia
Wow, lucky you I guess. Windows 8.1 has never installed the correct drivers for me.
    i7 3770
    ASRock B75 Pro3-M
    AMD R9 270X
TechnoMage
Active Member
Central Florida
If it's not obvious, then at least possible, that you don't get your Windows 8.1 ISO from the same source where I get mine.
Everything I download is "New and Improved" so to speak. It will contain the very latest driver pack, similar to Win-10, and security upgrades.
Ever consider changing your OS source?
TM :cool:
    Win-8.1/Pro/64
    Acer X-1200
    AMD 2 Core
    Acer
    Crucial, 4GB
    NVIDEA GeForce 9200
    On Board
    24" Acer
    Sandisk, SSD 500GB
    Acer
    SFF Slimline
    emachines 101 key
    Logitech Wireless
    5 Meg
