Metro storage location
davehc
Where are the metro desktop icons/apps stored? I want to group them, instead of the present very poor arrangement of showing every single app separately.
    Use several different computers during a day, so specs are irrelevant.
Bill2
2 possible locations, you'll need to muck around.
%USERPROFILE%\AppData\Local\Microsoft\Windows\Explorer\TileCache------.dat
and
C:\ProgramData\Start Menu\Programs
davehc
Thanks for responding. Unfortunately, if you are correct on the first link, it looks like it would need some hex work, which I want to avoid. The second link (which would be "C:\ProgramData\Microsoft\Windows\Start Menu", by the way) is not really what I am seeking. That leads into the "non" metro start menu, as in previous OSs
davehc
I didn't mean to say group. What I want to do is put items from the same program into a folder. At the moment I have 105 separate items on the desktop. This is dumb by any standard. In Windows 7 (or legacy) I have 10 folders, with folders within. As these folders are simply marked, it need two clicks to get to the one I want. lol It would probably take this old grey matter several weeks to know how far to scroll and look for the item on Windows 8.
Bill2
True, there doesn't seem to be any way to add folders to the metro start menu yet. If you aren't hung up on metro, just disable it and switch to the win7 style desktop gui.
davehc
Did that already Bill. Agasin, disappointment. Ended up with my usual desktop, just like Windows 7 but minus a couple of things and plus nothing extra. Looks like this dissatisfied customer will have to wait for the BEta (hopefully)
Kodi
Geriatric Member
I have got Rocketdock working on the 64bit version,you could try that.
    Windows 10 Pro 64bit
    Home Custom Build
    Intel i7-4770K
    Asus Z87 Sabertooth
    16 Gig DDR3-2400
    Gigabyte GT740
    Onboard
    Benq 27" - Benq 22" - Dell 23"
    1680x1050
    Samsung 840 pro 128g SSD
    1xWestern Digital Caviar Green 1TB
    2xWestern Digital Caviar Green 2TB
    Seasonic 760 watt platinum
    HAF-X
    Noctua NH-C12P CPU Cooler
    Logitech illuminated keyboard
    Logitech Performance MX
    Cable
    Avast Internet Security
