Metro glitch?
Omlet
14
So I powered on the computer today and was met with this:
The desktop is fine but the Charm Bar and Metro UI is totally bonkers. Any other reports of a similar issue?
    Windows 8 Pro
azasadny
Moved to ten*****s.com
I haven't encountered that yet....
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
Coke Robot
Gold Member
5,707
This kind of looks like the High Contrast theme has been switched on from PC Settings....
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
alphanumeric
slightly off center
Gold Member
I've had similar things happen. One day when I pressed the Windows key I got just a blank totally blue page/screen. Charms bar doesn't work but If I mouse down to the lower left corner and activate the metro screen there it opens fine. Then it works fine after that, for a while anyway. At random intervals it would do it again. I suspect its a video driver problem. It went away after a reinstall. It just recently its started doing something similar again. I'm just about ready to ditch my dual boot and go back to a Windows 7 only install. Desktop IE is acting up with blank pages and Outlook 2012 is also acting up with lags in displaying emails when you open them. In my case I'm pretty sure its the NVidia graphics driver that's the culprit.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Omlet
14
I do think it's a display driver issue; no amount of restarts fix the issue. It's actually pretty annoying since I have to mouse-over buttons in order to see what they say and the text is blurry. I hope a fix is implemented soon.
    Windows 8 Pro
alphanumeric
slightly off center
Gold Member
#8
Everything is readable for me, when its there. I was playing BackGamon the other day and the play buton was MIA. I clicked where it should be and the game launched. I've got an older GT220 so that may be part of the problem. It works fine in Windows 7 though so its not physically defective, it just doesn't like the current Windows 8 Drivers..
    Asus
    Thermaltake TR 620
    Stock heatsink fan
