Solved Metro apps keep running in the background after closing
antares
241
Hi, whenever I open a Metro app like Weather, even after closing it using the red cross in the upper right corner (feature added in 8.1 Update), the app will keep running in the background forcing me to end it with Task Manager. Is this normal?
    Windows 8.1x64 Pro
    self made
    Intel Core i7 6700K
    Asus Z170-A
    Corsair Vengeance LPX 32GB (4 x 8GB) DDR4 2400MHz
    Intel HD Graphics 530
    Onboard Realtek HD
    LG 23EA53 23" LED IPS
    1920x1080 32bit
    Samsung 256GB 830 Series SSD main+HGST 4TB 7200RPM as 2nd internal
    Thermaltake Toughpower Grand 850W TPG-850M
    Corsair Obsidian 650DW-1 Midtower
    Noctua NH-D14
    Logitech K800
    Logitech M510
    NIS2014
23,454
Hello Antares,
Yep, when you close an app with the red X on the upper right corner it only suspends the app to the background. When an app is supended, think of it as being placed in standby mode. The app will not use any system resources if suspended. A suspended app will still sit in memory (RAM) until that memory is needed by something else in Windows 8 and is then closed automatically to free the memory. While the app is sitting in memory, it will allow the app to be loaded faster the next time you open it since it's already in memory.
The tutorial below can help show you how to completely close an app though. :)
http://www.eightforums.com/tutorials/4125-apps-close-windows-8-a.html
    3 x 27" Asus VE278Q
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
antares
241
Thanks Brink for that tutorial, worked great.
    Windows 8.1x64 Pro
    self made
    Intel Core i7 6700K
    Asus Z170-A
    Onboard Realtek HD
    1920x1080 32bit
    Noctua NH-D14
    Logitech K800
    Logitech M510
    NIS2014
23,454
You're most welcome. :)
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
