Metro Applications and PC Settings don't start after click
PedroDSantos
Hello,
My Metro Applications and PC settings don't start after i click in it...
I click on the icons and the application don't start.
The Metro applications were working fine, but they stopped working.
Anyone have this problem or anyone know how to solve it?
Thanks
    Samsung 300E5C-05PT
    i7-XXXX
    6GB
    AMD RADEON 7670M + INTEL HD 4000
R0bR
Try running System File Checker, open a command window with administrative priviledges and type "sfc /scannow" (without quotes).
    Windows 7, Windows 8 RP
PedroDSantos
Thanks for the answer, what is this going to do?
    Samsung 300E5C-05PT
    i7-XXXX
    6GB
R0bR
It's going to scan your Windows install and fix any corruptions you may have, if you're lucky it will fix your problem. After a Windows Update all my non native Windows 8 Apps disappeared from my Start Screen and no longer showed up in my All Apps list. I ran this command and they all showed up again. It's not a new command, it existed in Windows 7 as well.
PedroDSantos
Hello,
Thanks...
It found an error and fixed it, but it still doen't work. I don't know what to do :( Please Help...
    Samsung 300E5C-05PT
    i7-XXXX
    6GB
