Hello,
I have been using W8 on my secondary computer. It does not get that much use. So I really haven't kept up with developments or features of the 8.1 upgrade. I had set up W8 by removing all cloud application (ALL) and replacing them with computer based programs. Somehow I perceived that 8.1 would allow me to do that and would have a start button, like it should IMHO.
I have either not installed it right, or have made wrong assumptions as I have updated just the other day. There seem to be tons of cloud apps and I can't get rid of them the easy way. How would one go about turning off all cloud access, finding and deleting all cloud based apps and replacing them, as I did on W8????? Help!!!!
It appears that there is no way IMHO to make a recovery disk. A bunch of NEW apps listed!! I do not ever wish to sync or store or access any clouds.
Thanks for any information and assistance. I basically used W8 as it worked well and fast on an older computer!
Regards,
glennc
Regards,
glennc
- Windows 7
