Max Processor State 99%
bassfacer22
Banned
209
Hello, new joiner here..
I have been reading about setting the processor power settings in the control panel to help with Gaming..
I have read one time that I should set "max processor state" to 99% so as to disable TurboBoost which apparently can heat up the computer playing games too long.. or help with pausing/freezing in games..
Can anybody shed some light on what decent settings the Max and Min Processor State % should be at??
So i put Minimum State at 10% and Max at 99% is there a reason why I wouldn't put Min state at 99% and Max state at 99% besides overheating? I am doing this on a Lenovo Laptop.. Plugged in though.
oh and if anyone knows the latest guide on how to setup settings for A SSD harddrive I would love to know that too.. I've looked at tomshardware guide.. but its from like 2013..
thanks
    Windows 8.1 (HOME not Pro) 64bit
    (So not very nice) Lenovo Y410P
    i7 quad 2.4Gig
    16G ram
    nvidia 2gig 755m
    Samsung 840 Evo
    supercache2 m2. mini card.
    Win Defender
CountMike
Belgrade , Serbia
4,664
Those power settings for Lenovo I'll let somebody with like model to answer but can help with SSD.
You are right about those recommendations for SSD, most are even older than 2013. Most important part is to have AHCI mode enabled in BIOS, the rest is practically same as for HDD. Nothing special unless it's an old or tiny one.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
bassfacer22
Banned
209
The picture in the 1st post Is not Lenovo Settings by the way... they are the typical Windows 8 Advanced power settings that all Windows users have to change..
thanks for the answer though.. but I'm still unsure about setting it at 100% or 99%.. its something to do with the way it boosts if at 100 then it will cause more freezing then stable playing of games or such...
edit- Oh and Count, I researched more on SSD hard drive setups.. apparently there is another something important which is Alignment.. apparently causes big speed increase if for some reason your drive is not aligned.. other than that i've seen info about Cluster size when you format the drives.. but its not a big deal like alignment..
    i7 quad 2.4Gig
    16G ram
    nvidia 2gig 755m
    Samsung 840 Evo
    Win Defender
CountMike
Belgrade , Serbia
4,664
If you install Windows on it, it will be aligned.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
bassfacer22
Banned
209
What would be a good way to benchmark my computer after changing the "max" and "min" processor state settings in the advanced power settings?? I don't want to test hard drive speed, (like Crystal disk or ATTO etc..)
so I don't know a good tool to test cpu after changing max and min processor state?
    i7 quad 2.4Gig
    16G ram
    nvidia 2gig 755m
    Samsung 840 Evo
    Win Defender
CountMike
Belgrade , Serbia
4,664
You can use Passmark Performance Test 8.0 to test all the components separately and all together. It's not free but have one month of tryout I believe. Should be enough to do tests you want. Or maybe Download UserBenchmark - MajorGeeks
Home is not exactly benchmarking program but lets you test components and see how much loading can CPU and other components take.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
gulls777
36
No point changing the minimum processor state.
Changing the maximum to 99% will disable turbo boost, which will result in lowered "maximum power usage" thus less heat.
This can help in gaming on a laptop as CPU isn't as important in gaming, and less heat from CPU will leave more room for GPU to run at max.
I keep turbo boost off on my laptop. Heat is not the issue, but turbo boost causes frequent high/low spinning of fan even in light usage which is annoying.
With turbo boost off, fan runs smoothly at lowest RPMs mostly and cranks up only when i throw something heavy at it.
And i can't tell performance difference in day to day usage.
    Windows 8.1 Enterprise x64
    Dell XPS L702X
    Intel Core i7-2760QM
    Intel HM67
    Samsung 16GB DDR3 1333MHz
    Nvidia Geforce GT 555M
    Crucial M4 128GB
    Samsung 1TB
theveterans
179
#8
Turbo Boost should not really cause fan to ramp up when done in bursts. Your uefi/bios might have an aggressive fan profile on the embedded controller firmware that ramps up when CPU goes to Turbo state. If your laptop has a quiet fan setting, that would alleviate the problem and you can freely use turbo without annoying fans while doing regular tasks.
    Windows 8.1 Pro x64 with Media Center
    Tablet
    Surface Pro 3
    Core i5 4300U @ 1.9 GHz
    Surface Pro 3
    8092 MB DDR3-L 1.35 V SDRAM @ 1600 MHz
    Intel HD 4400 @ 200 MHz
    Realtek HD Audio
    Built-in 3:2 display
    2160 x 1440
    256 GB SSD + 128 GB micro SD
    36 Watt power brick
    Active
    On Screen Keyboard
    Surface pen
    300 / 20 TWC
    IE 11 Metro, IE 11 Desktop
bassfacer22
Banned
209
#9
the veterans, I literally cut a wire on my fan to motherboard to make the fan run at full speed 24-7 to cool the laptop.. how dumb is that that i had to do that?? but i did it anyway cause the fan noise doesnt' actually bother me.. maybe it will later when i'm in a small area with nobody making noise and all people here is my fan spinning but right now it doesn't bother me at all.. and funny enough it's almost soothing because it's a constant almost waterfall/wind type sound.. like when you go to sleep with a noise maker machine.. ha..
anyway, this is all due to the *******s Lenovo for putting hard-coded bios and strict heat control and fan measures on these laptops.. i learned my lesson to never go lenovo again.. for many reasons.. this is just 1 of them.. don't get me started on that.. just browsing the lenovo forums you see nothing but "doesn't work" "need help with performance" "slow this.." "broken etc.."
i gotta stop now..
    i7 quad 2.4Gig
    16G ram
    nvidia 2gig 755m
    Samsung 840 Evo
    Win Defender
theveterans
179
#10
Some manufacturers put amazing specs at really low prices, but then it suffers from inadequate cooling, early BIOS throttling of CPU at low temps, even when the CPU can tolerate close to boiling water temperatures, WiFi whitelisting, premature wear and tear, etc.
For me, I like silent device so I use a Windows tablet for fanless operation though I still use my Windows 7 laptop for heavy typing.
    Tablet
    Surface Pro 3
    Surface Pro 3
    Realtek HD Audio
    2160 x 1440
    36 Watt power brick
    Active
    On Screen Keyboard
    Surface pen
    300 / 20 TWC
bassfacer22
Banned
209
#11
this is the grand slogan/statement/mission/company profile/who we are/ complete example of :
Lenovo Computers.
    i7 quad 2.4Gig
    16G ram
    nvidia 2gig 755m
    Samsung 840 Evo
    Win Defender
