Solved Max Payne 3 Cinematic sound gone.
I AM LEGEND
Hi to all Eight forum.
I installed and Play Max Payne 3 when I using windows 7. on installing win 8 64bits mp3 did not start as it should be. so I do some steps then the game is working know, these are the steps for those who did not yet able to start mp3 on 8.
1. install steam
2. install ms game live
3. install Rockstar social club
4. copy Rockstar games folder which is located on previous windows document folder. (anyone not so stupid that he will not save this folder before clean installing windows)
5. rename mp3 folder to MaxPayne3. (remove the space between Max and payne)
6. go to regedit and this entry
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Rockstar Games\Rockstar games
now right click on "installfolder" entry on left hand pane. and click modify. and change the location of rockstar games to actual game folder where you installed it.
in my case: the path is this:
then game must be working.
now my question is I m facing no sound only on mp3 cinematics. other gameplay sound are comes.
any suggestion would be very appreciated.
    Windows 8 64 bits Pro with Media Center
    Dell Inspiron N4050
    2.1 Ghz Intel mobile 950
    Dell 02JCHC
    4gb (2x2gb) DDR3 1333
    Intel(R) HD Graphics Family
    1366x768
    4mbps
I AM LEGEND
hahaha, what the hack is this,, cinematic/cutscene audio came automatically, I didn't do anything for this,
just install some softwares for some other purpose. like
Hand Break (video ripping tool)
Mkv Toolnix.(mkv merging tool)
Microsoft Essential 2012 (for movie maker only)
and I noticed one thing in add remove program there is Microsoft SQL server 2005 compact edition install, I think its install with MS Essential (their install date are same).
maybe one of this software pick up the mp3 cutscene audio, I don't know, maybe some programer should know..
so, the thread marked as solved.
    Dell Inspiron N4050
    Dell 02JCHC
    1366x768
    4mbps
crapcon
Registered to this forum just to thank I AM LEGEND. Installing Hand Break + Windows Movie maker does the trick! Must've been a codec issue then, since the cutscenes are videos (.bik format). Thanks mate.
(Running win8.1 x64)
    MS-DOS handsome frog
    Giorgio Armani
    Pentium II
    3MB ultra
    One with a fan!
    It has one
    Big ones
    20x30
    Got 21" on my ride
    Vanilla Ice stickers baby
    over 9000
    Netscape explorer 1.0
    The NSA has my back
    Bitches see my spec, they be hatin
