Manage Wireless Networks - i miss it... how to............
camar0rs
So I have 2 hidden wireless networks at my work
with windows 7 I would have a list of my hidden SSID networks and could easily switch back and forth
why did this change with windows 8?
I have to use "Hidden Network" and manually input the information from the wireless icon - dumb!
either way, switching back and forth between hidden and non hidden network it always asks for my password! wth ???
suggestions ??
    windows 8 pro
chev65
Closed
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
chev65
Closed
yes i have seen these articles and i know how to connect to a hidden network
the point is it does not save the passphrase when switching between hidden and normal SSID....
I would think that the check box to remember to connect automatically would work but it may work differently for no SSID broadcast.
Have you manually typed in the network name, type of security and the network security key on the Manually connect to a wireless network page "link below". Access for that page is through the Network and Sharing Center. It's best to remove the old wireless profile before manually creating the new one.
How to Connect to Hidden Wireless Networks in Windows 8 | 7 Tutorials
Maybe it's not remembering this information for security reasons or there is a problem with switching between the two, but it seems like it should be able to save the settings.
Certain types of wireless connection software can also cause this problem, the ones that install along with the wireless NIC drivers are notorious.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
camar0rs
I just don't get why Microsoft changed this feature... I don't like it.... I wish they had kept the workaround shell command but so much for that..... bah!
    windows 8 pro
camar0rs
is there a way to even create like a shortcut on the desktop to connect to a wireless profile ? I could live with that
    windows 8 pro
chev65
Closed
As far as I know they didn't change it, but there are other things that can cause this type of problem like connection software.
With no SSID broadcast it is mandatory to fill out the manual wireless profile from the Control Panel, that procedure should definitely be working and saving all sign in credentials.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Yep...it's the same way in windows 7.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
chev65
Closed
I'm pretty sure that someone isn't following directions exactly as printed in the link which requires you do fill out the wireless settings manually through the control panel.
Either that, Or the connection software that installed with the wireless device is causing the problem.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
