Low speed internet despite high speed provided by ISP
offroad
6
Dear friends
Could you help me figure out why it is that I have trouble browsing in high speed despite the fact that the wireless adapter receives data at 1 Mbps minimum? I haven't been able to watch videos on Youtube, read the news etc because the browser takes ages to load the full page. I checked which applications are connected and they haven't exchanged much data as you can see below:
Excuse my English!
Thank you.
    Win 8 32-bit
    Intel Core 2 Duo (64-bit)
    2 GB
Don't you think that running bit torrent in the back ground has something to do with this problem or is that just for testing connection?
Between bit torrent and using an outdated wireless G connection you really can't expect much here, you may be paying for a faster service but the use of 802.11g is a bottle neck for this connection. Going to 802.11n router and wireless adaptor would be much better.
Looking around for a better driver might help.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
offroad
6
I don't think Bit torrent has any influence here but it is OK. On the other hand, this router has always intrigued me, sometimes it works, other times it doesn't. It's an old Lynksys router that has worked for years now. I have a D-link N wireless adapter but I haven't noticed any improvements, to be honest, the built-in G adapter works a little 'faster'. I will see if I can convince the building manager to buy a new router, if that is possible at all. :think:
    Win 8 32-bit
    2 GB
I'd say that in general you won't be having good connection speeds when running torrents with a wireless connection.
If you have access to the router you can try changing wireless channels and use the non mixed mode 802.11g settings to improve things. Windows 8 will probably work better using WPA2 security with AES encryption.
With wireless G connection speeds limited to 54Mbps you are short on bandwidth so going to wireless N hardware would probably improve things dramatically although you would need to use the wireless N only settings and use channel bonding.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
richardkg
1
If you are downloading or seeding in the bittorrent, it can make the browsing slow no matter how high speed the internet is.. If there is no activity going in the bittorrent client then in normal cases it won’t affect the browsing speed. It doesn't matter that you have an 802.11n wireless adapter if your router is old and supports only 802.11g. Your adapter can receives only what your router sends. Check if your router supports 802.11g wireless mode. As already mentioned in above comments try changing channel to one with least interference. Also check in a different wireless device. Also try re configuring the device. If still no improvement try to get a newer router from a friend , configure and try it. I think that will pinpoint the issue to, whether it is a router issue or internet service provider issue.
    Windows 7
CountMike
Belgrade , Serbia
4,664
Did you try Speedtest.net by Ookla - The Global Broadband Speed Test with and without torrent running ? What is the bandwidth your ISP promised ?
1 Mbps may not (and it isn't) enough to watch higher resolution Youtube videos when doing just that, let alone downloading something else at same time.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
