Low FPS without charger in
lebanese
39
graphic card : GT 740m
i play a browser game on chrome named begone nplay .
with my charger plugged in i get 100-130 fps but whenever i unplugged it it drops to like 20-40 fps . i checked power settings and its always on high performance . i dnt know what to check also . pls help i dnt want always to put my laptop on charger.
    win 8.1 64
    lenovo Z500 touch 20221
    intel core i7 3612QM
    31900004WIN8 STD SGL
    8 GB DDR3
    nividia GeForce GT 740M , intel hd 4000
    1 TB HDD
    chrome
    win defender
    network adapter : intel(R) Centrino(R) Wireless-N 2230
lebanese
39
why no one answer :sarc:
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
CountMike
Belgrade , Serbia
4,664
Because the answer is obvious, Laptops drop power to save battery when running on it alone and so drop the speed of whole machine. You can try to put Power Options to High performance but than battery will last much shorter time.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
lebanese
39
thats no an answer !! :doh: i know that !!!!!
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
CountMike
Belgrade , Serbia
4,664
Ok than, either run games with power plugged in or wait for better answer. Good luck with changing laws of physics.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
bye
9
Hey there!
I think I understand your problem. While you say that your PC is on 'High Performance' power plan with and without the charger, I still see one more possibility and that is that the High Performance power plan is configured to save battery when on battery. This can easily be fixed.
All you need to do is to go to the advanced settings of the High Performance plan from power options and wherever possible, make the 'On battery' and 'Plugged in' settings same. This will result in similar performance with and without charger but will also cause your battery to drain super fast. If you are still unsure what I told you to do, I have posted some screenshots here.
On a side note, I have a suggestion for you. When you are seeking help, you shouldnt sound like "thats no an answer !! i know that !!!!!". Instead, a polite tone like "I know that, thats not what I am looking for" should work better and you wont need to change the Laws of Physics.
Cheers!
    Windows 8.1 PRO
CountMike
Belgrade , Serbia
4,664
Hey there!
Cheers!
There's a lot of other settings in Power Plans that enables one to make a PP even on an laptop to set to performance similar to a ordinary desktop computer but as he stated that he "knows that" I did not want to explain further. I'm not one that wants to change somebody's believes, being religiious or computer ones.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
bye
9
#8
Look, I posted a possible solution a few hours ago and I see you were here about an hour ago. If your problem gets solved you should reply here so that this thread is marked as solved. If its not solved, you should tell that its not solved.
    Windows 8.1 PRO
