Solved locked out and require help with clean install
evprop
10
I have locked myself out and cannot even get into msconfig because a box keeps popping up saying "cannot access specified path, file or folder etc"
I read someone saying i need to do a clean install, but i cant reset my pc. It just says there was a problem and it cancels.
What can i do?
    dell
    i5 2.50ghz
    6 gb
    geforce gt 650m
Can you pull up Task Manager any way ?
By pressing Ctrl+Alt+Delete ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
If you have a Restore point or 2:
If you can access Task Manager, Click on File at top left & choose create new task.
In the create new task window, check the tiny box saying run task as administrator & type CMD into the textarea.
Click ok or whatever & an administrator command prompt will appear.
Type in rstrui.exe & press Enter.
System Restore will popup.
Choose the suggested restore point & follow the prompts.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Saltgrass
1,121
I saw a thread the other day where someone had the "Drive I locked" message and it was related to the drive becoming uninitialized. I checked and if I had an uninitialized drive and checked it with Diskpart from a command prompt, it would say the drive was locked and if I tried to list the partitions, it said there were none present.
I suppose I am suggesting you boot into the command prompt in the Recovery Environment and check the drive with Diskpart. If you can boot into the command prompt, and need commands, let us know.
    Windows 8.1 x64
    Home Grown
    i7 3770K
    ASUS P8Z77 -v Pro, Z87-Expert
    16 G
    EVGA GTX 680 Classified (2)
    Kingston SSD 240 GB
evprop
10
hey guys... thanks for the help after reading a ton here and everywhere i can find i will try and list the things i have tried that i can remeber doing and also what my system is doing:
Things I have done:
Reset
restore.. says there is no restore points or something along those lines
refresh...... all of these say there is a problem and it closes
net user administrator.. got it up but gives me no extra leverage to bent the system to my will.
normal running mode i cant access admin command prompt
safe mode i can and i have checked CHKDSK chk partitions etc all there and have 3 recovery partitions
i have tried rstrui.exe but no luck
i have gone to microsoft website and tried installing windows 8 and windows8.1 with my product key and failed both times because my product key cant be used for a retail version of windows 8.... really annoyed me, win8 came with my new machine!!
Things my system wont let me do:
Everything involving administrator roles period.
Things i can do:
open files and folders
use browsers
hope this helps you guys in helping me... pulling my hair out lol
    dell
    i5 2.50ghz
    6 gb
    geforce gt 650m
theog
Gold Member
5,591
Windows 8 came with my new machine!!
Use the OEM manufacturer's Recovery DVD's or USB drive.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
evprop
10
@theog
It came preinstalled and i didnt make a recovery disk.... i realise too late this is something i should have done
    dell
    i5 2.50ghz
    6 gb
    geforce gt 650m
Clintlgm
Active Member
Lacombe, Louisiana
894
#8
@theog
I found this Clean install guide for Dell Notebooks, perhaps you can modify the drivers to the correct ones for your Unit.
You will need to disable secure boot and enable CSM in your BIOS.
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
theog
Gold Member
5,591
#9
@theog
How to order Microsoft official Dell OEM manufacturer's Recovery Disks.
Manuals | Dell US
    Notebooks x 3
    Desktops x 5
    Towers x 4
evprop
10
#10
Right sorted it!!
My problem:
single user account on my system seemed to have been infected and i lost all admin access, i couldnt change anything!!
could not refresh, restore or reset back to factory settings.
Fix:
safe mode
command prompt (admin)
regedit
  • hkey local machine
  • software
  • microsoft
  • windows
  • current version
  • policies
  • system
Click on system:
On the right hand side you should see a list of files, look for "EnableLUA" Double click.
A box will come up with details of:
Valuename: Enable LUA
Valuedata: 1
Base: Hexadecimal
If this is what you see then you need to change the data value to: 0 and restart your system!!
Problem fixed and you have full control on your pc!!
No re-install required it should just all be working normally again
Really hope this helps someone in the future
    dell
    i5 2.50ghz
    6 gb
    geforce gt 650m
TechnoMage
Active Member
Central Florida
395
#11
Thank you!
I copied that fix and printed it out, for my "Repair Notes" folder, that I carry with me in my 'Kit' on every service call.
I hope that others, reading this thread will save that 'Fix' as well.
Thanks again!
And, Happy New Year!
TechnoMage :cool:
    Win-8.1
    Gigabyte
    AMD 8 Core
    Gigabyte
    PNY, 4GB
    NVIDIA, GForce 210
    21" HP
    Seagate SATA III, 500GB
    Antec Earthwatts, 650
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
    AVG Free
    Using Classic Shell on Win-8.1 pro
evprop
10
#12
Also make a note that this does not fully solve the problem.
After using it for a while i noticed there were still problems with what I could do with the system, but at least I was able to finally reset back to factory settings
    dell
    i5 2.50ghz
    6 gb
    geforce gt 650m
