Lock Brightness settings?
ionbasa
Yucaipa, California, USA
Well, I have installed Windows 8 on my laptop, but was wondering if there is a way to lock the screen brightness.
The reason being is that family members constantly mess with the brightness and sometimes leave it at 100% when using the battery. I basically want to extend the life of the battery if it is possible by disabling or locking the screen brightness at a certain level.
    Windows 8.1 Pro w/ WMC x64
    HP Pavilion g7-1350dx
    AMD A6-3420M APU
    4 GiB DDR3
    AMD Radeon HD 6520G
    IDT HD Audio
    1600x900
    Hitachi HTS547550A9E384 SATA Disk Device (500GiB)
    Synaptics PS/2 Port Touchpad v7.5
    IE10/Chrome Beta/Waterfox(64bit)
    Windows Defender/ MalwareByte's Pro
Hello Ion,
Sure, you could specify a default setting for them in group policy (gpedit.msc), at the location below.
Computer Configuration -> Administrative Templates -> System -> Power Management -> Video and Display Settings
Hope this helps, :)
Thanks, but wouldn't it still be changeable using the function keys on the keyboard?
    AMD A6-3420M APU
    4 GiB DDR3
    AMD Radeon HD 6520G
    IDT HD Audio
    1600x900
I'm not certain about that. I don't have any to test with.
locking is impossible I think. it is changeable and I think it is very easy and takes few seconds to set back via function keys
    win 8
