Limited Ethernet- No Connection
Labber
20
Problem - I cannot at all connect to the internet.
Details -
NETWORK
Connections is Ethernet Limited.
HARDWARE
positive that adapter router modem works.
Already installed network drivers (REaltek LAN Drivers, windows 8 64 bit)- GIGABYTE - Motherboard - Socket FM2+ - GA-F2A88X-UP4 (rev. 3.0)
ipconfig all-
Ethernet adapter VMware Network Adapter VMnet
Tunnel adapter isatap
Tunnel adapter Teredo
Where Autoconfiguration IPv4 address in VMware adapters are 169.254.248.31 & 169.254.196.141
Details -
NETWORK
HARDWARE
ipconfig all-
If you can post the ipconfig/all it might help. Need to type or paste that into an elevated command prompt.
The auto address indicates that you can see the router but aren't picking up an IP from it.
The VMware may be problematic here depending on a few things. What are you using it for?
Have you tried to reset the router?
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Labber
20
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : CoolerMasterHAF
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet
1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
Link-local IPv6 Address . . . . . : fe80::e9f1:7ba:3cab:f81f%16(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.248.31(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 536891478
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-34-DE-AB-00-1E-8C-19-EF-C7
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Link-local IPv6 Address . . . . . : fe80::4990:59bc:845e:c48d%17(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.196.141(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 553668694
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{7809618F-B86F-4187-BFDF-B636E53D4006}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.{346DA5FA-AC2B-48FA-94A2-772911874CA5}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
VM is just a linux distro on top of windows. (so in a way just average uses, using chrome downloads etc.)
Thanks.
I really haven't tested Windows 8 on what looks to be two different VMware connections so can't really give tips on how to make it all connect but from what I'm seeing this connection can see the router but isn't picking up a connection from it.
The auto configuration is just what Windows shows when it's not picking anything up from the router.
But I have to ask, how can you expect this to work when DHCP is disabled on both adaptors?
So I guess without adding static IP's you can't really connect unless DHCP is enabled.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Oh, sad. Thanks though. Anyway, I did have internet before and after VM. After a long time, this happened, out of the blue.
But are you using static IP addresses? Or can you try to enable DHCP on the IPv4 properties.
If this worked at one time have you tried to reset TCP/IP or winsock? Or the router?
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Labber
20
Yeah, those are totally above my head I dont understand them :D. I dont have the connection on my computer, in network and sharing center it says you are not connected to any networks and when I try to click set up network nothing shows up. Thanks
#8
Oh I'm sorry, you need to go to the IPv4 properties then enable DHCP so it can pick up an IP address.
It's showing up as disabled in the ipconfig.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
sml156
115
#9
Your Ethernet card is not showing up it might be disabled or not working . To enable it right click on the network icon on the taskbar and select open network and sharing center then select change adapter settings
The only Ethernet devices I see are VMware and Tunnel adapter's
    Windows 10 Pro + 8.1 pro and 7 Utimate
    i3 2.53GHz
Labber
20
#10
IPv4 seems enabled. For the ethernet I right clicked and clicked diagnosed and it said there might be a problem with the driver which is weird as I already installed the latest drivers and I even tried the microsoft provided ones.
