Lenovo problems!
ampie
My lenovo G480 or sımılar model has crashed
It ıs about 2 months old and ıt froze for the fırst tıme causing me to force shutdown by holdıng ın the power button for a prolonged amount of tıme. However when I started ıt up agaın ıt saıd loadıng fıles then proceded to the startıng lenovo screen wıth the cırclıng dots loadıng ıcon... I dont know what to do. I am a teacher and I need to use my lapop desperately.
please help
thanks Ampıe
    wındows 8
Snubs
Hi Ampie, I don't fully understand. Do you mean it crashes every-time you boot up? or is it doing a loop? Thanks!
    AMD FX8150 8 Core 3.4Ghz
    ASUS
    8GB DDR3 1600
    ATI HD6950
    HP 2310i
    60GB - Boot Drive
    3TB - Media Drive
    750GB - Data Drive
    500GB - Games
    500GB - Games (Raid 1)
    Maelstorm
    Microsoft Wireless Keyboard 3000
    Microsoft Wireless Mouse 3000
    1 MB/s
Snubs
Are you able to access Safe Mode?
    ASUS
    8GB DDR3 1600
    ATI HD6950
    HP 2310i
    60GB - Boot Drive
    3TB - Media Drive
    750GB - Data Drive
    500GB - Games
    Maelstorm
    1 MB/s
ampie
nope. ı trıed the onekey rescue system but ıt gıc-ves me 4 optıons.
start normally
bıos setup
boot menu
System recovery
ı have trıed start normally and system recovery yet neıther works. and ı am afraıd that ı am too ıncompetent to understand bıos setups or boot menu
    wındows 8
Snubs
It might be worth doing a Check Disk. Will fix any corrupt windows files. If you can access Safe Mode via command prompt then great, if not you will need to get there via the advanced system menu. When / if you get there run
[B]chkdsk /F C:[/B]
or
[B]chkdsk C: /F[/B]
. More info on tech-net site: Run Check Disk from a Command Line to Check for and fix Disk Errors. (you maybe able to access Command Prompt by the boot menu, not 100% sure)
    ASUS
    8GB DDR3 1600
    ATI HD6950
    HP 2310i
    60GB - Boot Drive
    3TB - Media Drive
    750GB - Data Drive
    500GB - Games
    Maelstorm
    1 MB/s
ampie
I cant seem to get to the command lıne: ı pressed f8 and got to the advance boot optıons. ı trıed both safe mode and safe mode wıth command prompts then ıt just go3es to the lenovo screen. for really long.
there are other optıons though
enable boot loggıng
enble low res vıdeo
debuggıng mode
dısable automatıc restart on system faılure
dısable drıver sıgnature enforcment
dısable early launch antı malware drıver
whıch one should ı take?
    wındows 8
Snubs
    ASUS
    8GB DDR3 1600
    ATI HD6950
    HP 2310i
    60GB - Boot Drive
    3TB - Media Drive
    750GB - Data Drive
    500GB - Games
    Maelstorm
    1 MB/s
Snubs
Its annoying because if you could access command prompt you could run a SFC scan which would probably fix the issue. If you have a windows 8 disk you could boot from that and run the Command Prompt under the "Repair your computer" option.
    ASUS
    8GB DDR3 1600
    ATI HD6950
    HP 2310i
    60GB - Boot Drive
    3TB - Media Drive
    750GB - Data Drive
    500GB - Games
    Maelstorm
    1 MB/s
Snubs
Is that including booting off a windows 8 disk?
    ASUS
    8GB DDR3 1600
    ATI HD6950
    HP 2310i
    60GB - Boot Drive
    3TB - Media Drive
    750GB - Data Drive
    500GB - Games
    Maelstorm
    1 MB/s
XweAponX
please help
thanks Ampıe
If it crashed and you had to force it off, yo may have damaged your hard drive. Windows 8 does this. Download Hiren's Boot CD from my link below, burn it and boot to it. Stick it in the Lenovo and boot to it, go do DOS PROGRAMS and then go to hard Drive Tools.
Try GWscan. If GWscan does not work, you will have top use the program for the OEM, Like Toshiba or Hitachi, you'll have to know who made your hard drive. Your System BIOS will tell you this- You should probably find out before you run anything.
In GWscan if it runs, let it do the first 2 tests, if it finds Read Element Failure, then run the full disk scan, it takes an hour. The OEM programs also have full disk scanning. It will detect an error, then offer to fix it, that's what you wanna do.
Once it does the full scan, then just reboot, run CHKDSK on your system drive as soon as it comes up.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
XweAponX
Ok great - Scan your hard drive with one of the tools on Hiren's as SOON as you can, after you do that, you can try something else - If you need to. But I bet it is read element failure.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
ampie
ok, so i put hiron on the cd, and yet it still doesnt work, also accessing dos from boot requires another cd, is there any other way to access a cmd line from boot. I know how to access the advanced bios though. sigh.
    wındows 8
XweAponX
Well you need to boot from the hirens disk. You will see a screen of options, you want "dos programs" then "hard disk tools"- find GWscan and run the first 2 tests.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
