Solved Lenovo G580 audio problem
lenny111
4
Hello.
I have a Lenovo G580 with Windows 8. I have a weird problem with audio. If the default audio is set as internal speakers and I plug in my headphones the sound just keeps coming from the internal speakers. But if I set the headphones as default, I can switch between the speakers and headphones as I want and there is no problem if only I play music from my computer.
If I try to play something from my browser, however, the sound only comes from the internal speakers and connecting the headphones does nothing. Except (and this is where it gets weird) if I play something from my computer first using the headphones. Then I can play anything from the browser and hear it through the headphones as long as I don't plug them out. If I plug them out, the sound switches back to the internal speakers and trying to plug in the headphones again doesn't do anything. So I have to play something from my computer again with the headphones plugged in and then switch to my browser to again play everything through my headphones.
What's wrong with it? Any way to make it work as it should work?
    l
popeye
United States
3,090
Hi lenny111, first question would be what make of audio chip and have you downloaded the latest 8.1 drivers?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
my2cents
Veni, Vidi, Vici
2,191
(Wild guess) Any chance you have your audio configured to something other than 2 stereo speakers?
Control Panel> Sound> Select Speakers and click Configure (button)
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
my2cents
Veni, Vidi, Vici
2,191
Also, are your Headphones shown as "ready?"
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
my2cents
Veni, Vidi, Vici
2,191
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
lenny111
4
Update: The problem seems to be exclusively in Firefox. All works as it should in Explorer and Google Chrome.
Thanks for the suggestions, though: It's set to 2 speakers. They are shown as ready. That's the place where I went for the drivers too.
    l
my2cents
Veni, Vidi, Vici
2,191
#8
Firefox? very strange indeed! So, what version of FF are you using? The latest appears to be FF25.0 and there is also a flash update available as well (if you have not already installed it):
So, did you just discover this issue after updating to a newer version of FF or Flash? Can you confirm if it ever worked before when using FF?
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
lenny111
4
#10
Sorry for the delay. I tried different versions of Flash, which didn't help much. Then I decided to try out different versions of Firefox. First one tried was 24. And that did the trick! Everything works as it should now. Thanks everyone!
    l
MrFox
1
#11
Hello.
I had similar problem on my kid's laptop. No sound, not in Firefox, but completely.
I deleted Conexant driver and searched for compatible drivers in the system (locally).
It found Conexant driver and Standard Microsoft High-Definition Audio Device.
I have installed the last one and it works now.
Also I had to chose speakers instead of headphones. It does not change automatically.
Before I found the solution they used Bluetooth headphones to get sound out of this laptop.
    Lenovo G580
    Intel Pentium B960 @ 2.20GHz
    LA-7982P
    4,00ГБ Single-Channel DDR3 @ 665MHz (9-9-9-24)
    1023MB NVIDIA GeForce 710M (Lenovo)
    IE11
